Page 2 of 15 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 150
Thread: Check Here For Updates!
  1. #11
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    public release 4B- Some important bug fixes
    die bug die!
    finally squelched that nasty bug allowing mouseclicks/finger pokes while windows are animating. could cause some really annoying problems see below for all...
    Public Release 4B-
    Main Application
    New Features: None
    Bug Fixes: fixed an issue where the user could send events while windows are animating, which in turn could cause the interface to become unresponsive if the key window was changed during an animation
    fixed a rather moot bug where the incomplete modules wouldn't exit completely causing a problem that would result in an unresponsive interface if the user entered the main application options without clearing the erroneous state by entering the music module
    Changes: None
    Known Issues: Using expose can have dire consequences (I can only duplicate when the visualizer is open). (may not ever be fixed so the best solution at the moment is to not use expose)
    Music Module
    New Features: Added ability to start playing tracks from an artist/album selection by pushing the playbutton which previously had done nothing
    Bug Fixes: Fixed an issue where pushing previous/next would start playing a song unless music was already playing
    Improved accuracy when the table views determine if a row was clicked or if the user had scrolled to a different selection
    Changes: changed the table views to both show the background instead of just one of them
    had to change the visualizer not to animate out of view when closing (somehow moving the window off screen would cause problem that could lead to a crash if the user would repeatedly open and close the visualizer)
    Known Issues: None
    check us out at: www.neonboombox.com
  2. #12
    Feb 2008
    I decided one more fixer up wouldn't hurt before I move on to release 5.
    please enjoy. get it from the usual place.
    Public Release 4C-
    Main Application
    New Features: Added ability to show/hide mouse in the general preferences
    Bug Fixes: Nothing noticeable
    Changes: tweaked the layout and appearance of general preferences
    finally got around to making the sliders change color
    dead code stripping
    Music Module
    New Features: None
    Bug Fixes: added more boundary checking in the AAC atom parser so prevent buggy behavior with somewhat corrupted or lousily constructed AACs (seen with some podcasts)
    Changes: minor speed boost when playing a new song
    Known Issues: None
  3. #13
    Feb 2008
    Public Release 5-
    Main Application
    New Features: key bindings to controls tab- change focus space- execute x-close window up/down rotate dial
    added a master volume controller visible in any options even in any module options
    Bug Fixes: fixed a slew of problems with accurate dial creation and rotation. it is now 100% accurate.
    patched some memory leaks
    fixed an issue where the mouse would become visible (when set to be invisible) when the application becomes active such as after waking from sleep
    fixed a crash resulting from attempting to rearrange the module button in focus after launching a module
    fixed an issue that would allow a background window to move forward
    Changes: dead code stripping
    made the dial drawing more efficient
    marginally improved app launch time
    dial has a new layout which now only supports 10 modules. (future release may see dynamic resizing)
    consolidated dial rotation code
    smaller memory footprint
    combined all window subclasses into a hierarchy to facilitate future additions/changes and to simplify things and reduce repeated code hopefully alleviate some bugs more easily
    tableviews now back their selection with a colored oval (changes color with the rest of the interface) instead of a gradient
    overhaul of application graphics and color
    Known Issues: hitting the action key while dragging the dial can get it into some interesting positions
    Music Module
    New Features: user can now configure the browser screen to their choosing (still has just 4 active buttons at the bottom, but they can drag replacements in as well as rearrange the active buttons)
    added several new filter choices. (playlist, song, audiobook, podcast... not yet active except for song)
    beginnings of key binding support (user can scroll lists and choose selections, but no music control)
    added a module volume controller in the preferences so user can set music volume (will eventually be a factor of master volume)
    added the ability to jump to sections in the active list by typing the first letter (virtual keyboard coming soon)
    enhanced the ability to play all songs from any given selection by double tapping/clicking the selection (artist/album/etc)
    added support for track number on now playing screen
    Bug Fixes: changed track time to be a larger data type in order to allow for longer tracks. long tracks could previously cause an overflow.
    Changes: completely new music browser. now only one window with a split view. much easier to manage
    track duration now decrements to reflect time remaining
    track times now calculate to allow for hours had previously so now a track that is over an hour now reflects that so a track that is an hour and 14 min will now show 1:14:00 instead of 74:00 for example
    various graphical improvements
    overhaul of module graphics and color
    added an album art reflection
    Known Issues: Visualizer can cause application to crash on rare occasion (expose induced)
    Buttons at the bottom of the music browser don't have a focus ring but are in fact active. put your memory to the test
    no way to get back into the responder chain once stepping off it with tab (without using a mouse/finger)
    sorry once again for the extraordinary delay. Ill try not to let it happen again ;-)
    will be posted on our site shortly
  4. #14
    Maximum Bitrate pepsibobby's Avatar
    Dec 2005
    Kaiserslautern Germany
    maybe its just me, but when i go to the site, i can only see release 3b.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
  5. #15
    Newbie NeonBoomBox's Avatar
    Aug 2001
    neonboombox.com download page has been updated! yay!
    Take a peek >>> www.neonboombox.com
  6. #16
    Dec 2005
    its still showing the same for me.
  7. #17
    Aug 2001
    im not sure why its showing the same for you but if you click the download link you will get the latest and greatest
  8. #18
    Aug 2001
    OOPS! If your Neon Boombox messes up when you close the prefs window in the music player head on over to neonboombox.com and re-download NBB. Sorry for any inconvenience we may have caused
  9. #19
    Feb 2008
    Release 5B
    Public Release 5B-
    Main Application
    Bug Fixes - Addressed an issue where unhiding the mouse may not actually unhide the mouse
    Changes - brightened up the color for the buttons just a bit
    Music Module
    New Features - Added playlist support W00T
    - Added a reference to the currently playing track in relation to the total number of queued tracks in the "now playing" screen
    Bug Fixes - Visualizer now reports the album track number for the song instead of 0
    fixed a bug where embedded jpg Mp3 album art wouldn't display if it was stored as jpeg instead of jpg
    Changes - Music module now reads the itunes preferences regarding the itunes library location
    Known Issues - the volume controller can be a bit stubborn about changing color at times
    Now digging into some big changes/additions in release 6
  10. #20
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Brighter colors = better. I meant to ask about this, thanks.
    Want to:
  1. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  2. Just an FYI: CHECK THE VOLTAGES!
    By dbzeag in forum Power Supplies
    Last Post: 06-13-2006, 04:22 PM
  3. C.A.M.P. Project revealed! please check it out
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 04-12-2001, 08:52 PM
