Just curious if it will be possible to browse by song title in the next release?
By the way, VERY nice work. I was surprised that I actually like it as I didn't think I'd be a fan. However, what goes in the games section?
yeah the video module has been just a simple test for now. I am actually working on it right now and have player controls wired up and working I think you all will find them very satisfactory. by the next release (prolly wednesday) that will have been fixed along with a whole host of other problems like random, not that you would notice video random not working ;-)
check us out at: www.neonboombox.com
ummmm. you can browse by song title now... go into the music module prefs and click the configure filters button and drag the song button to the bar. is that what you meant?
you can arrange the filter buttons in any order just like the main interface dial buttons.
games hasn't even been scratched. at the moment the plan is a simple port of snes9x.
thank you for giving it a chance. I find that alot of people are quick to criticize without even trying it, but those that do usually end up liking it. especially after finding all the unique features that aren't available anywhere else, like color changing and dynamic control arrangement
I must say Neon...very good work so far. Once you get the Apple Remote functionality to it...it should be golden to me since I'm primarily using Front Row.
Also would it be possible to link the iTunes Visualizations or have some sort of Spectrum Analyzer Visualization to it just for something different when you can get to it. Thanks in advance.
no I don't know of any way to link to the tunes visuals... if somebody else does I would gladly listen. More visualizers are on the way... the current visualizer is actually a spectrum analyzer, however... did you mean something else or just one that is more simple.
If you would like to make one it is rather easy. They are made in apples quartz composer. you simply need to publish certain inputs for the audio spectrum and song info. I can help you with that
hope its a bit more stable than 7A
still have no beta testers...
going up on the site right now.
Public Release 8-
Main Application
New Features:
Bug Fixes: fixed an issue where the mouse would not hide when the visualizer or movie player was brought to the front
Changes: the custom slider has a bigger nib to drag
Known Issues: some minor issues drawing the volume bar on resolutions higher than 800 px wide
Music Module
New Features: added a preference to set the default table row size
Bug Fixes: fixed a minor issue where having shuffle set would affect the starting song in the playlist and therefore could potentially keep songs from being played (unless repeat was on)
fixed a minor memory leak
fixed a potential crash when toggling shuffle while music was playing-
Changes: reduced the default row size by a bit
made a new button for configuring the display filters
Known Issues: nothing new
Video Module
New Features: added a playback controller. tap the video to bring it up. only play/pause, previous track, next track, close, and back to the browser at the moment
shuffle now works
repeat now works
Bug Fixes: fixed an issue where the wrong videos would be loaded into the table
fixed a problem where the video module would overwrite the music player preferences
Console output:
4/30/08 10:36:29 AM [0x0-0x44044].com.Project-X.NeonBoombox[340] objc[340]: Class PXSliderCell is implemented in both /Applications/Neon Boombox.app/Contents/MacOS/../Frameworks/NeonBoomboxSDK.framework/Versions/A/NeonBoomboxSDK and /Applications/Neon Boombox.app/Contents/MacOS/Neon Boombox. Using implementation from /Applications/Neon Boombox.app/Contents/MacOS/Neon Boombox.
4/30/08 10:36:29 AM [0x0-0x44044].com.Project-X.NeonBoombox[340] objc[340]: Class PXSlider is implemented in both /Applications/Neon Boombox.app/Contents/MacOS/../Frameworks/NeonBoomboxSDK.framework/Versions/A/NeonBoomboxSDK and /Applications/Neon Boombox.app/Contents/MacOS/Neon Boombox. Using implementation from /Applications/Neon Boombox.app/Contents/MacOS/Neon Boombox.
4/30/08 10:36:29 AM Neon Boombox[340] initializing dial...
4/30/08 10:36:30 AM Neon Boombox[340] ModuleController initialized...
4/30/08 10:36:30 AM Neon Boombox[340] custom slider awake
4/30/08 10:36:30 AM Neon Boombox[340] hue:0.000000
4/30/08 10:36:30 AM Neon Boombox[340] incorrect data check
4/30/08 10:36:30 AM Neon Boombox[340] loading (9) module(s)...
4/30/08 10:36:30 AM Neon Boombox[340] appdelegate attempting to insert to dial...
4/30/08 10:36:30 AM Neon Boombox[340] remaining button count:10 module:<PXGamesModuleController: 0x1840f0>
4/30/08 10:36:30 AM Neon Boombox[340] module:PXGamesModuleController index:0
4/30/08 10:36:30 AM Neon Boombox[340] loaded module: com.Project-X.PXGamesModule
4/30/08 10:36:30 AM Neon Boombox[340] remaining button count:9 module:<PXGPSModuleController: 0x194a40>
4/30/08 10:36:30 AM Neon Boombox[340] module:PXGPSModuleController index:1
4/30/08 10:36:30 AM Neon Boombox[340] loaded module: com.Project-X.PXGPSModule
4/30/08 10:36:30 AM Neon Boombox[340] remaining button count:8 module:<PXInternetModuleController: 0x19a480>
4/30/08 10:36:30 AM Neon Boombox[340] module:PXInternetModuleController index:2
4/30/08 10:36:30 AM [0x0-0x44044].com.Project-X.NeonBoombox[340] Wed Apr 30 10:36:30 tom-berrys-power-mac-g4.local Neon Boombox[340] <Error>: incorrect data check\n
4/30/08 10:36:30 AM Neon Boombox[340] loaded module: com.Project-X.PXInternetModule
4/30/08 10:36:30 AM Neon Boombox[340] initializing movie controller
4/30/08 10:36:30 AM Neon Boombox[340] opening iTunes XML
4/30/08 10:36:32 AM Neon Boombox[340] using location:~/Music/iTunes/iTunes Music Library.xml
4/30/08 10:36:32 AM Neon Boombox[340] iTunes XML opened
4/30/08 10:36:32 AM Neon Boombox[340] dividing library tracks
4/30/08 10:36:32 AM Neon Boombox[340] compiling tv shows
4/30/08 10:36:32 AM Neon Boombox[340] compiling music vids
4/30/08 10:36:32 AM Neon Boombox[340] compiling podcasts
4/30/08 10:36:32 AM Neon Boombox[340] scanning playlists
4/30/08 10:36:32 AM Neon Boombox[340] font sixe:30
4/30/08 10:36:32 AM Neon Boombox[340] appdelegate attempting to insert to dial...
4/30/08 10:36:32 AM Neon Boombox[340] remaining button count:7 module:<PXMediaViewerController: 0x19ed10>
4/30/08 10:36:32 AM Neon Boombox[340] module:PXMediaViewerController index:3
4/30/08 10:36:32 AM Neon Boombox[340] loaded module: com.Project-X.PXMediaViewer
4/30/08 10:36:32 AM Neon Boombox[340] initializing music controller
4/30/08 10:36:32 AM Neon Boombox[340] opening iTunes XML
4/30/08 10:36:33 AM Neon Boombox[340] using location:~/Music/iTunes/iTunes Music Library.xml
4/30/08 10:36:33 AM Neon Boombox[340] iTunes XML opened
4/30/08 10:36:33 AM Neon Boombox[340] incorrect data check
4/30/08 10:36:33 AM Neon Boombox[340] font sixe:30
4/30/08 10:36:33 AM Neon Boombox[340] toggle shuffle
4/30/08 10:36:33 AM Neon Boombox[340] appdelegate attempting to insert to dial...
4/30/08 10:36:33 AM Neon Boombox[340] remaining button count:6 module:<PXMusicController: 0x57b63a0>
4/30/08 10:36:33 AM Neon Boombox[340] module:PXMusicController index:4
4/30/08 10:36:33 AM Neon Boombox[340] loaded module: com.Project-X.PXMusicModule
4/30/08 10:36:33 AM Neon Boombox[340] remaining button count:5 module:<PXPhoneModuleController: 0x5dcb030>
4/30/08 10:36:33 AM Neon Boombox[340] module:PXPhoneModuleController index:5
4/30/08 10:36:33 AM Neon Boombox[340] loaded module: com.yourcompany.PXPhoneModule
4/30/08 10:36:33 AM Neon Boombox[340] *** Assertion failure in -[PXPhotoModuleController initWithWindowNibNamewner:], /SourceCache/AppKit/AppKit-949.27/AppKit.subproj/NSWindowController.m:95
4/30/08 10:36:33 AM Neon Boombox[340] An uncaught exception was raised
4/30/08 10:36:33 AM Neon Boombox[340] Invalid parameter not satisfying: windowNibName
4/30/08 10:36:33 AM Neon Boombox[340] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Invalid parameter not satisfying: windowNibName'
4/30/08 10:36:33 AM Neon Boombox[340] Stack: (
2441318132,
2493749100,
2441317892,
2495655396,
2509628484,
90764,
11488,
2494676472,
2440747360,
2441374468,
2509425520,
2509390196,
2509388568,
2509387508,
2509386716,
9508
4/30/08 10:36:33 AM [0x0-0x44044].com.Project-X.NeonBoombox[340] Wed Apr 30 10:36:33 tom-berrys-power-mac-g4.local Neon Boombox[340] <Error>: incorrect data check\n
4/30/08 10:36:44 AM ReportCrash[341] Formulating crash report for process Neon Boombox[340]
4/30/08 10:36:47 AM ReportCrash[341] Saved crashreport to /Users/tberry/Library/Logs/CrashReporter/Neon Boombox_2008-04-30-103634_tom-berrys-power-mac-g4.crash using uid: 501 gid: 501, euid: 501 egid: 501
4/30/08 10:36:46 AM com.apple.launchd[109] ([0x0-0x44044].com.Project-X.NeonBoombox[340]) Exited abnormally: Trace/BPT trap
Want to:
actually the filters are dynamically created so if something is showing up multiple times it is a bug. prolly easily fixed by deleting your prefs. try opining the music module prefs and clicking configure filters for a full range of options. there should be album, artist, song, playlist, podcast, books, and genre
