oh man that is weak! i thought iTunes would add anything that QT could play for some reason...
not at this time tho later versions will likely add new
video sources now that i see iTunes won't add non ipod compatible
videos...
one thing you could do to get them to show up is to manually edit the iTunes.xml file and add the videos to it yourself, but eachtime you open and quit itunes that file is rewritten so that wouldn't work if you are using itunes on your mini for anything besides the initial library setup...
it probably won't be that hard for me to just add movies from the movies folder to the NBB movie library but they would all be categorized as movies and have not tag info.
