Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 63
Thread: Roadmap for Neon Boombox
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by NeonDev View Post
    @bugbye
    do you have an XM PCR, an XM direct, or XM commander? I know the PCR will work and that the direct and commander can work with the same protocol, but I cannot test or verify it.
    I have an XM Direct. Works well using the mp3car adaptor under Windows on Streetdeck.
    I suspect I would have to use my keyspan serial adaptor and cable to use it with the Mac.
    Want to:
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    any mac compatible open source solutions for navigation?
    Roadnav
    Want to:
  3. #13
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    Quote Originally Posted by Bugbyte View Post
    how do you connect it to the PC?
    if you plug it into the mac does a new device show up in the /dev directory in terminal?
    as long as it does I should be able to communicate with the device using the same protocol as the XM PCR I just have to do something special to put it into command mode
    so im told...
    check us out at: www.neonboombox.com
  4. #14
    Feb 2008
    ok just a quick update based on all the feedback I have gotten in various forms
    Here is an Updated/tweaked roadmap
    1. add more visualizers and support for 3rd party visualizers
    2. add support for the apple remote
    3. update and release a new SDK
    4. create a bare bones XM radio control module (XM PCR for sure others if i can)
    5. add support for basic themes/skins
    6. create some alternate themes. (might need help on this one)
    7. add support for using an ipod as a library source
    8. add support for dvd playback
    really the only change is I squeezed a new SDK release in there. This is because there is alot of demand for GPS related features that I cannot accomplish myself in the short term. I have had offers from others to see what they can do if I can provide them with a proper SDK. No promises on what comes of their efforts.
    If they cannot create a GPS/navigation module I will attempt a port of roadnav once I acquire a compatible loner/donated/purchased GPS module, and only after I have completed number 4 on the list. XM has to come first because it is only possible by the grace of a kind donor and I promised to get a bare bones solution for it ASAP.
  5. #15
    Feb 2008
    anybody have any thoughts on where the on screen keyboard should fit into the road map. NBB has had that search button for awhile and I want to make it finally fulfill its purpose.
    If it effects your thoughts at all implementing it would prolly take no more than a day of work. now if only i can find the time to do anything this week. It will likely be another week at least till I have some free time due to my actual job. I haven't done anything programmatically for NBB for almost a week...
  6. #16
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    First of all, thanks for your work on NBB, I've been using it full-time in my car since I got my screen installed over the weekend. I would definitely like to see the search function working, since I don't have a rotary controller set up yet and touchscreen scrolling is just too finicky to use while driving. I would certainly appreciate it more than new visualizers.
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  7. #17
    Feb 2008
    well i can hardly argue with that. my goal is to get both apple remote integration, on screen keyboard, and support for third party visualizers working this weekend.
    I also plan on releasing the new sdk this weekend but I'm not sure when i will have time to write documentation for it...
    after that has to come the XM module. which itself prolly won't take more than a weekend; the trick is to find the time...
  8. #18
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    Will you also incorporate LineIn somehow so when the XM module is active LineIn is also?
  9. #19
    Feb 2008
    no not if i can help it. what does linein do that is so great? I'm pretty sure i can do audio passthrough natively.
  10. #20
    Feb 2006
    NJ
    oh ok....i didnt know if you were going to include passthrough or not...my bad
  1. Neon Boombox users guide
    By NeonDev in forum Neon Boombox
    Last Post: 09-09-2008, 06:18 PM
  2. RoadRunner roadmap
    By LagunaICE in forum Road Runner
    Last Post: 06-18-2006, 08:33 AM
  3. PyCar roadmap
    By jbors in forum PyCar
    Last Post: 03-29-2005, 08:08 AM
  4. MediaCar Boombox!
    By zahirsk in forum General MP3Car Discussion
    Last Post: 06-03-2004, 05:29 PM
