Results 1 to 10 of 16
Thread: My Car PC setup with M4 ATX
    Feb 2009
    Friends,
    I have bought a M4 ATX Power supply and decided to go with the following config. for my new Car PC. Please let me know will 250w enough for this and also provide your suggestions.
    Motherboard: Gigabyte GA-EG31MF-S2
    Graphics: Sappire HD 4350 512 MB
    RAM: 2*1 GB DDR2 RAM
    Proc: Intel E6700
    HDD: 300GB Seagate SATA 7200.8
    Wi-Fi+Bluetooth 2 in 1 adapter
    3MP CCD Webcamera
    16GB USB Pen Drive
    So my question, will the above setup can be handled by M4-ATX? If I connect any DVD Drive or 60mm fans, will it be OK?
    Any suggestion for a better processor like E7300/Q6600 over this?
    FLAC WuNgUn's Avatar
    Sep 2007
    What are you using for sound??
    Your likely going to run ito problems, especially if you use PCI sound card.
    One word: OPUS
    Dec 2008
    um depending on your climate i would stick with a lower power setup and one that generates less heat. I chose and intel board with the atom chip integrated, im using the onboard sound and video with 256md of video ram, 2 gig ddr2 memory, and 16 gig SSD hard drive etc etc and my machines run of less then 1.5 amps and runs cool even with ambiant heat in the car. OPUS or Mini-Box are great but im going to tell you that if your gonna run a quad core cpu with the choice of video card you made you gonna need more power then a M4 ATX can give you.
    My desktop is a quad cored and i have an equivelant geforce 9800 and i use a 650 watt power supply and it runs at peak all the time so if your trying to use a 300 wat M4 ATX i would see if you can put 2 in there cause you will need both
    Feb 2009
    I am not limited by the space factor as I can install 10 more desktop PCs in my car boot(its TATA SAFARI). So I choose a Micro ATX Cabinet.
    Currently I am not going to use any Sound card, but may be a ASUS Xonar in future if power permits.
    The graphics card is a low profile one and it takes only 20w at maximum load.
    The Motherboard is the best energy efficient one and my proc is Core 2 Duo E6700/7200. As per the review in http://www.tomshardware.com/reviews/...1,2039-13.html the motherboard and proc takes maximum of 70w at full load.
    Will I am fine? Should I need to switch to a 2.5" SATA HDD instead of a 3.5" HDD?
    Will I need to use E7200 instead of E6700?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Not so much the load of the PCI card as the vibration. Just make sure you have it bolted down firmly. I've dealt with several threads over the past years where they thought the hard drive was bad and it turned out to be a PCI card or power connection.
    Want to:
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    No need for such proc power. Use a MB which has most of the stuff integrated.
    Slovenia, Europe
    best on-line radio
    Feb 2009
    No plan for external sound card now.
    The motherboard is an energy efficient one and as per http://www.tomshardware.com/reviews/...1,2039-13.html the board with E7200 will take only 70w at max. load.
    The graphics card is a fanless low profile card and it takes only 25w at maximum load.
    So I have 150w left.
    Will I need to use a 2.5" HDD instead of the 3.5" HDD?
    And the external USB Hub is self powered. Will I need to change to E7200 instead of E6700 (I have a spare E6700 with me!!!)
    No friend, I cant trust the atom proc. as I will do some graphics works, need to run two external headrest monitors (dual display).
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Thread moved, new topic was added to the Newbie section.
    Tidder
    Try RevFE
    Feb 2009
    Firends,
    I bought a new 10.4 touchscreen LCD Display today. It has a film attached to the screen with lot of bubbles. It looks weird and ugly. Is it the protective film or anything for the touchscreen functionality? Can I remove the film, will it affect the functionality of the touchscreen. please guide me.
    Sep 2003
    New Mexico, USA
    It sounds like it's the cling wrap type of plastic cover to protect the screen. You can remove it.
    Tidder
    Try RevFE
  1. New to Car PC, here is my setup.
    By BarinaHum in forum Newbie
    Last Post: 11-06-2006, 09:16 PM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
