Results 1 to 3 of 3
Thread: My setup so far
    Mar 2009
    My setup so far
    Hi all.
    After much reading on these forums I have started my project. This is where I am up to now:
    Intel DG945GCLF
    1gb memory
    250gb SATA laptop drive
    M2-ATX supply
    GPS receiver (installed in front window, but it looks more like an alarm thing)
    Centrafuse software (with Igo-pc)
    Mobile broadband dongle
    Still deciding on what screen I should get (lilliput or Xenarc)
    Up to now I have installed the wires required. I have a 4g wire (fused near battery) running to a 4 way distribution block, down to 8g wire powering 2 amps (this has been like this for the last 5 years, so this is running fine). These are earthed together at the back of the car.
    Then running a 15amp (16g) power cable to the M2-ATX from the distribution block. The earth for this is just connected to the body of the car (16g wire).
    I also have the IGN cable from the M2 running to a kill switch so I can stop the Pc from firing up if needed.
    I'm just awaiting delivery of my Voom box then I can connect it all up!
    I'm going to install a RJ45 connection as well (somewhere) and a USB hub so I can transfer files etc.
    How does this all sound up to now? Any suggestions?
    Oh the car is a Nissan pulsar (Almera) N16 series one hatchback.
    Cheers all
    Jonathan
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    My only opinion to do something else of what you have done, is to skipp the cabeled wire (RJ-45) and go WiFi instead... Is hundre times easier than hooking up a cable every now and then.
    Mar 2009
    Yeah I thought that after I typed it:-)
    Fortunately I haven't done that bit yet, so I'll look at a usb wi-fi adapter and have the usb port easily accessable, so i can have it plugged in when needed.
  1. What kind of setup do you have for a PCMCIA Card?
    By polo6979 in forum Wireless Communications
    Last Post: 04-18-2008, 12:36 AM
  2. Help with general setup
    By Blup in forum Newbie
    Last Post: 01-11-2008, 12:50 PM
  3. Centrafuse 1.2 won't leave setup
    By marchello2000 in forum CF Bug Reports
    Last Post: 07-03-2007, 12:18 PM
  4. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
  5. new setup pics
    By freestyler in forum General MP3Car Discussion
    Last Post: 06-06-2002, 01:08 AM
