Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: here is what I am thinking...
  1. #11
    Low Bitrate lbergamo's Avatar
    May 2009
    Michigan, USA
    Could you give some more details in regards to this "magic box".
    Thank You
  2. #12
    May 2009
  3. #13
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    Yea It looks like you should be able to plug the rca cables from that box into the input of the sound card, you would need a RCA -> 3.5mm(headphone jack) adapter. Or you could leave the audio output not plugged in and not have the dinger.
    The only issue to that would be if you had an onboard sound card that only has 3 jacks and you have it set to 5.1 mode, then it usually switches the input to the rear speaker output. But if you got a soundcard then you would definitely be able to do it.
    Also the sound wouldn't only come out of the speaker when the computer is on.
    Another option would be to put the output from that box directly into your amps, using a RCA Y cable with two inputs and one output. That way the sound would come out whether or not the computer was on.
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
  1. Ok so I am thinking about taking the plunge
    By Valhalla in forum MacCar
    Last Post: 06-30-2006, 08:46 PM
  2. Thinking of trashing the MII12000 and getting a 2Ghz Celeron
    By miztahsparklez in forum General Hardware Discussion
    Last Post: 06-22-2006, 11:46 PM
  3. Thinking Of Getting New Car
    By [HoP] in forum General Hardware Discussion
    Last Post: 05-13-2006, 11:10 AM
  4. Thinking about going manual..
    By Song0330 in forum Off Topic
    Last Post: 02-21-2006, 04:34 PM
  5. Tricking the head unit into thinking the mp3car is a cd changer
    By SeenaStyle in forum General Hardware Discussion
    Last Post: 05-02-2000, 01:06 AM
