Cool mount. I just bent a bunch of L brackets but that is much more precise.
You don't have to swap out your drive. My Mini has never missed a beat in several years of use in the car.
Alright so I wouldn't be posting in the newbie forum if I wasn't a newb, so I don't need to explain that. I have a 2009 Mini Cooper that's about eight months old now and instead of purchasing the $2000 Nav System, $500 Sat Radio, etc for my car new I've settled on setting up my own system.
I happen to have an extra Intel based Mac Mini lying around so that shaves a good bit off my up-front price. I'm going to replace the 80GB 7400RPM HD in it with a 60GB OCZ SSD for cooling and motion purposes. I was also planning on running a shaved down version of Windows XP Pro on it for compatibility reasons, maybe I'll switch back when I can find (or make) a better Mac OS frontend.
Here's what I have in mind so far:
OCZ 60GB SSD
Lilliput EBY701 7" VGA Touchscreen
Carnetix 2140 PSU
Mac Mini Power Adapter for Carnetix PSU
BU353 GPS Receiver
XMPCR Satellite Radio
Powered USB Hub
Mac Mini Mount
Proclip Mount
Now here's the plan. I'd like to mount the Lilliput using a Proclip mount if that's possible. I'd also like to mount the Mac Mini itself under the passenger seat, I've seen a few threads involving setups in Mini Coopers but I have yet to see anyone use this space.
Here are my main questions:
- What type of mount from Proclip fits the Lilliput monitors if there is one?
- Do you think the space under the passenger seat will work well?
- Are there any other concerns I should be aware of?
Thanks in advance for your help, I know that the Mini isn't exactly a 'universal' car so running wiring and such could be tough. Any help would be greatly appreciated!
Corc
Want to:
I know I probably but don't need to swap it out, but I'd also prefer the virtually negative seek time of the SSD. Good way to speed up my boot speed too IMHO.
Corc, did you ever find out what Proclip mount would work for the Lilliput 7" touchscreen? I just got my EBY701 to go in my 09 MINI Cooper S and I think a proclip would be the best way to mount the display. If you didn't use a Proclip, what did you use instead?
Thanks for your help!
Chimera
