Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Proposed hardware for first CarPC
  1. #11
    Jul 2008
    Yeah we want pics!
  2. #12
    Thanks Fellas!
    I will do pics...first time and all. I was looking at the the 4th gen mo-co-so case as seen here:
    http://store.mo-co-so.com/4th-gen-mi...-pc-p-178.html
  3. #13
    I am wondering where I can find numbers for the max power draw for my planned devices? Without being able to measure the power consumption first hand, I can only guess at what my max usage under load might be.
    I found the mobo...I guess i will search around on google.
  4. #14
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Sometimes Newegg will have the specifics on 'em. I know Western Digital says on their website the power consumption of their devices.
  5. #15
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Oracle View Post
    I have been on the fence for a while about doing this project but finally made up my mind.
    Looking for system stability and dependability in my Mazda 3 and am considering the following hardware:
    --Intel D945GCLF2 Atom 330 mobo /CPU combo.
    --DDR2 667 240 pin memory )2GB stick)
    --WD Scorpio Blue 500GB SATA (already own)
    --Sony Optiarc Black 8X DVD+R SATA Slim 8X Slot Loading DVD Burner
    --HD Radio (Visteon HDZ300 or Connected DMHD1000)
    --MitchJS serial cable interface for HD radio
    --M1-ATX 90 Watt (I want to power LCD touch screen, all drives and mobo)??
    --Lilliput 629 7" or Lilliput EBY-701 7" or some other LED powered touch Screen??
    --GPS mouse of some sort or a cable for my existing Hollux BT GPS reciever.
    I am undecided on a mini-itx case and a 4 channel amp for the car.
    Could use any help for recommendations or suggestions you all might have.
    Thanks!
    I would go with a M2-ATX, that will cover the MoBo, Screen and all devices, other then that it all looks good. If you do get the EBY701, I like to mention a flaw in the screen. While using it, if you accidently hit the auto adjust button it can not use 800x600 resolution anymore. Im so scared of hitting the button that I actually removed it from the case.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread moved to proposed setup.
    Want to:
  7. #17
    Thanks HiJack.
    I wasn't aware of the EBY701 issues. Very good to know though. I may go with the 629 instead.
    Quote Originally Posted by HiJackZX1 View Post
  8. #18
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    The only real power requirement you need to get is the motherboard/cpu and video card if you have one, everything else is pretty standard from device to device.
    Also keep in mind that if you get that case, there isn't anywhere to put a PCI card, so if you ever wanted to put something in the PCI slot you would need to get a new case. Just thought I would point that out in case you missed it
    Edit: No pun intended
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
  1. Replies: 1
    Last Post: 08-25-2007, 05:44 PM
  2. Registration and hardware codes...
    By ccrobin in forum StreetDeck
    Last Post: 08-22-2007, 11:14 AM
  3. Hardware Review: Car2PC Alpine MBUS review
    By MatrixPC in forum The Review Palace
    Last Post: 06-02-2006, 07:39 AM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  5. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
