Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Newbie with a starting project
  1. #11
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by lionelrs View Post
    http://store.mp3car.com/ATC_FUSES_p/sup-060.htm
    This will do the work? if so, how do I put it between the car battery and the DC-to-DC controller?
    (Whats the difference between an ATM fuse and an ATC fuse?)
    Another question:
    If I want to add a wheel so I could control the volume or scroll up\down the menu,
    How do I add it?
    Is it OK to use the Fusion Brain for it? (and to add features as I like)
    http://store.mp3car.com/product_p/com-089.htm
    thank you very much =] !!
    Its help me understand what is it possible to me to do on the car and what are my limitations.
    Quick google search found this:
    Quote Originally Posted by Wikipedia
    Blade type
    Plug-in fuses (also called blade or spade fuses), with a plastic body and two prongs that fit into sockets, are mostly used in automobiles. These types of fuses come in four different physical dimensions: mini (or minifuse or ATM), low-profile mini, ATO (or ATC) and maxi (or maxifuse).
    The physical dimensions, including the connector, of the fuses are as follows (LxWxH) (ampere ratings in the parenthesis):
    Mini: 10.9x3.6x16.3 mm (2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A)
    Low-Profile Mini: 10.9x3.81x8.73 mm (2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A)
    ATO: 19.1x5.1x18.5 mm (1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A, 35A, 40A)
    Maxi: 29.2x8.5x34.3 mm (20A, 30A, 40A, 50A, 60A, 70A, 80A, 100A)
    You can use a fuse holder: http://store.mp3car.com/ATC_10_gauge..._p/sup-044.htm
    Check out the Griffin Powermate for volume control/scrolling: http://store.mp3car.com/Griffin_Powe..._p/com-052.htm
    Or search the forums for Volume Control...You'll find a million threads about it. Here's a start: $10 volume knob fabbed for hacking up a mouse and using Volumouse
    Yes, you can use a FB. I'm not sure if it's possible to use it with linux though. Browse the FB forums for more info on what's possible: http://www.mp3car.com/vbulletin/fusion-brain/
  2. #12
    Newbie lionelrs's Avatar
    Jun 2009
    Just to be sure I understand to what you answered me
    Is it possible to connect a volume controller like that:
    http://store.mp3car.com/Volume_Contr..._p/com-080.htm
    to the FB?
    If not, Where do I connect the volume controller?
    (I don't really like the Griffin Powermate Volume Knob)
    If yes, is there a wheel like the volume but that isn't limited to 1 rotation?
    (Using for up\down menu control)
    Next Question:
    How do I connect the computer to the speakers in the car?
    How do I connect to the car radio antenna?
    I search for all the information that can help me and I saw that the connector from the car to the radio, there is a connection to the battery:
    How do I search for my car connector on the internet?
    Is it an option to connect the pc trough this?
    How do I connect to the car antenna for this: ?
    http://store.mp3car.com/HQCT_1_0_Hig..._p/com-009.htm
    So far so good
  3. #13
    Feb 2009
    to the FB?
    Yes
    There was an infinite spin knob in development, I don't know what happened to it. You may want to ask around the FB section. You can also look at these threads for other options:
    http://www.mp3car.com/vbulletin/inpu...uchscreen.html
    http://www.mp3car.com/vbulletin/macc...tion-knob.html
    Next Question:
    For sound: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
    You may need an adapter to connect your radio antenna. The HQCT has an SMB connection. You can get this: http://store.mo-co-so.com/index.php?...roducts_id=110
    It will allow you to plug in any standard motorola connection. Then if your car antenna isn't a motorola connection, you would have to buy an adapter.
    For me, I googled "Nissan Antenna Adapter" and found this: http://www.crutchfield.com/S-XAfQi31...a-Adapter.html
    Google a wiring harness for your car. If it helps, Metra makes a ton of different wiring harnesses.
    Look through the FAQ (Look through the FAQ...it will answer a lot of your questions: http://www.mp3car.com/vbulletin/advfaq.php) and use the Search on the forum. A lot of the questions you ask have been asked many times.
  4. #14
    Jun 2009
    nice summery =] thanks.
    now I searched up for a solutions of how to put the screen and the controllers in the car.
    but I didnt find a elegant solution that fits me, please help me.
    the example car is VW Polo Classic 1997.
    Where can I put the screen? I want it over the panel.
    Where can I buy the plastic panel? so I could fix it to the screen ( 7" touchscreen)
    How do I fix the panel (the plastic)?
    If there isn't a way to put it over the panel and this is the last result so the other option is to put the screen on metallic arm that can move and lock.
    If so, where can I find a car screen arm that move and lock, need to be small as possible and flexible and convenient for use.
    What arm do you recommend me? if theirs one.
  5. #15
    Feb 2009
    It would be great if you can post up some pics of the interior. I have no idea what you're dealing with with the VW Polo.
  6. #16
    Jun 2009
    Can't do it right now but still...
    You know where I can find car dash panel parts?
  7. #17
    Feb 2009
    For specific dash parts for your car, I have no idea. You can always make your own
    People in the fabrication forum have done some amazing work: http://www.mp3car.com/vbulletin/fabrication/
  8. #18
    Jun 2009
    WOW
    There are awesome works!!! really!
    but I'm a newbie, I can't find how they do it.
    What are the materials they use? From where they get it?
    How they make panel from nothing?
    How can I make a panel from scratch to my car?
    Or where can I find a step-by-step guide for "How to make..." with the materials needed.
    Is their any one who can make in for me if he knows what car I'm talking about and how it looks like?
  9. #19
    Jan 2009
    fiberglass
    if you want to makte it by someone it could cost like $180---$200
  10. #20
    Jun 2009
    Who can make it for me?
  1. Replies: 5
    Last Post: 04-28-2008, 08:11 PM
  2. Replies: 1
    Last Post: 02-18-2008, 01:54 PM
  3. Starting My First Project
    By hroo772 in forum Newbie
    Last Post: 03-20-2006, 09:53 AM
  4. Car Comp 2 project starting soon! Questions...
    By JBCrash in forum General Hardware Discussion
    Last Post: 05-04-2005, 04:10 PM
  5. Replies: 6
    Last Post: 03-01-2005, 02:32 PM
Tags for this Thread
