I don’t Post ever but I remember when I was Right where you are right now Ok lets start with this does your factory stereo system have a compact disk add option being a 09 model the answer is yes so I would do this and save a ton of headache and money This suggestion is a car stereo to pc interface I found doing research
http://indashpc.org/new/ what it does is it allows you to keep your stock
head unit amp and speakers it integrates the pc through the compact disk setting I personally have one in my cl600 Benz I have installed this interface on over 25 cars works great now that your
sound end of the system is in place its time for a car pc purchase mp3 car has all the components needed you already know what you want in the system lilliput monitors are standard and they offer many different options I haven’t seen your model auto so I will not suggest mounting options. The motherboard this will be your most important selection as I have a whole grave yard of motherboards that lets just say don’t work. My suggestion is an Intel atom for several reasons cost and they really work. Anything comparable is going to require a high dollar motherboard and a purchase of a low
power CPU. Here is a low cost board that I have been impressed with Intel D945GSEJT mini-ITX it has the power supply on board its ultra thin and it works well
music,
video, gps heck even any
wifi internet with an additional purchase of a USB wifi modem. The only down fall I can find is it’s a single core CPU. Plus you have to use the front speaker inputs with your stock sound system it does supply line out for more complex applications than your stock
radio supplies so all this means is purchase a case with the front jacks supplied to plug onto the motherboard front panel sound interface connector. Or check out this motherboard its the best atom on the market( my opinion)Zotac ION mini-ITX Dual Atom N330 spec: NVIDIA GeForce 9400M- 1 VGA/ DVI / HDMI- 6x Rear USB 2.0 - 1x eSATA - 1x PCIe- 2x DDR2 667 RAM - up to 4GB - 1 x 1x 10/100/1000 Mbit LAN - High Definition Audio- Power: 20 Pin ATX- RoHS compliant. Use at least a 150 watt smart psu (Pico) and another suggestion buy a
amplifier install kit it has everything needed for the PC hardwire I hope this helps with your first build
PS pay attention to the power requirements of each item you add to your system. An under powered power supply is frustrating and sometimes disastrous. When it comes to the power supply more is better.
