Results 1 to 2 of 2
Thread: help with two proposed systems kinda long
    Jul 2009
    ok still trying to decide between 2 proposed systems. any experience with a set up like this or comments are appreciated.
    things i already have are.
    lillyput 629 gl
    4th gen mocoso case with pci slot
    usb sirf III gps
    m2atx psu
    hd directed radio with rs232 interface cable
    mocoso usb bt
    andrea sunbeam bundle(mic with usb sound input)
    ok i still obviousley need the main parts. what im tring to decide is between
    first system is
    ZOTAC GF9300
    http://www.newegg.com/Product/Produc...82E16820231098
    cpu e7400
    http://www.newegg.com/Product/Produc...82E16819115206
    memory G.SKILL 2GB
    and hdd Seagate Momentus 7200.4
    http://www.newegg.com/Product/Produc...82E16822148452 or Intel X25-M
    http://www.newegg.com/Product/Produc...82E16820167005
    and a gigaport usb card
    http://www.esi-audio.com/products/gigaporthd/
    second choice is
    msi gm45
    http://www.logicsupply.com/products/ms_9818
    cpu P8600
    http://www.newegg.com/Product/Produc...82E16819111009
    memory unknown but most likley something along the g skill
    hdd would be the same two choices as above.
    pci card M-AUDIO Delta 1010LT
    http://www.newegg.com/Product/Produc...82E16829121011
    some kind of usb wifi
    i will probaly pick up a powered usb hub or two depending on needs.
    first system has more usb ports better graphics and on board wifi. also a bit cheaper. and i will need a usb to rs232 for the hd radio.
    second system has lower power(less heat right?) a pci slot for a better audio card(the m audio) rs232 connectors and seems like more upgrade posabilities in the future. also a bit more expensive.
    im also have trouble decieding between the 2 hdd choices. is the ssd worth the xtra money and less space?. will it cause any porblems?/ and will they system boot/read faster with the ssd?.
    either system will be running xp home and centrafuse. this will be going into two zapco dc amps a 650.6 for 6 rainbow speakers and a 1100.1 for the subs still looking at subs. all procesing will be done on the amps for the most part
    im ready to start ordering this stuff tonight but haveing trouble decieding. and with this being my first car pc build i could use some input.
    ive been searching the board for weeks but cant seem to find any concret information on a setup like these.
    Jan 2008
    ssd is give and take, it will give you slightly faster boot up times, the write time is seems to be close to standard drives (i think, i have a laptop drive, so don't take my word for it), they are also more expensive for less capacity, and the biggest issue thay have is writing data to them degrades them, but reading it does not--so some have used a ssd for os, and programs, and all other modifiable data gets written/deleted/read onto a standard hdd.
    for motherboards, i really perfer not to give suggestions--this is my opinion on the board you have selected, and only my opinion-- and everuyones got one, so don't just take mine...
    motherboard, processor, ram: i have heard good things about the zotac boards in general, and am very slowly planning my next carpc around one(once i feel that i must upgrade-- a couple years away). i am really not a big fan of msi, though i have never used one or plan to use them. the processor is fine, and the memory will be more than adequate, some feel that 2gb ram is too much for a carpc running xp-mostly becuase it can slow down hibernate times--i am personally running 2gb of ram and a intel 945gclf motherboard, and don't really care about shutdown or hibernate times, and have setup my system to shutdown instead of hibernating-- mostly for my gps logging program that doesn't like to go into hibernate.
    for the soundcard selection, i would definatly recomend the pci card solution over the usb solution, but am personally using the gigaport hd for all my audio, again, my intel board doesnt play nice with everything and so i had to go for a usb solution after the mo-bo decided it didn't want to boot when the pci sound card was inserted.
    i have had problems on and off with the gigaport-- i believe that most of them are user error, but some are equipment faults.
    if you choose to go with the gigaport-hd, and are doing it for the asio drivers-- and would like to use it for audio modification, DON'T. the driver and software package that come with it is useless for audio playback/modification for a car audio standpoint. just use the windows drivers, and asio4all. the biggest issue i had is that the asio driver is only a output, so in a Console, becsue it would only accepts 1 asio device, it was forced to use just the output of the gigport, and there were no inputs. this works fine with musicians who use midi devices as a input, but does not allow any computer sounds to be outputed from the sound card(again i might be doing something wrong, if i am, please correct me). i also had some problems after the esi software was installed- after the install, asio4all would no longer recognize the card(it threw a error that said that card was 'beyond logic'), and so i have been forced to use the windows drivers.
    i don't know how you are planning to set your audio up, so i will give you a quick rundown of my current setup as of 8-5-09(if you look back on my posts, my audio routing setup seems to change everytime i post).
    currently, i am using virtual audio cable to route the computer sounds into a program called asio4all, asio4all then sends the audio to Console, my audio setup program/ vst host (to sum this up, the easiest way possible, Console 'hosts' a bunch of little programs called vst plugins that modify the audio in different ways-you can add a crossover, or 31band eq, or time alignment, or whatever else is needed), after console changes the audio, it sends the audio back to the asio4all, which sends it to my gigaport sound card, which sends it out to the speakers.
    wow, long post, sorry, didn't plan to post this much..
  1. Replies: 6
    Last Post: 10-01-2007, 03:07 AM
  2. Long RCA vs Long USB
    By SKiTLz in forum General Hardware Discussion
    Last Post: 02-18-2007, 04:57 PM
  3. Using an old VGA TFT monitor... (kinda long)
    By MikeHunt79 in forum LCD/Display
    Last Post: 11-12-2001, 09:36 AM
  4. touchscreen (first post, kinda long)
    By poolguy in forum LCD/Display
    Last Post: 11-08-2001, 11:38 AM
  5. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 09:52 PM
