Results 1 to 10 of 13
Thread: 05 Chevy Colorado build.
    Jun 2006
    Hey all,
    Well i am looking to start in on my colorado build, and really only have on main question. I have done some searching for other colorado builds (only a couple that i saw), and was wondering if anyone has any input on the size screen that should be used?
    Otherwise, i will just have to wait until i pick it up to measure and go from there.
    Thanks for the help.
    Jan 2008
    screen size is completly up to you, and really depends on your overall requirements-- i believe that the colorado has a double din radio, so a bybyte frame, and 7" screen will drop right in with no modification to the dash. if you choose to go bigger than that, the only limit is how much, time money, and fabrication skills you have(i keep saying this hoping someone will beat me to installing a 42" touchscreen, so i won't have to ).
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I used an 8" in mine to get th efull 800x600.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Jun 2006
    Quote Originally Posted by fixerofallthing View Post
    Do you have the ability to send e some pictures of your setup?
    Jun 2006
    LOL, nevermind...i see the sig now.
    Jun 2006
    Ok so here is the layout of my stock radio
    It is 8 1/16" diagonal, 4 1/8" tall and 7 1/4" wide. so i thought that a 16:9 8" screen might work?
    http://store.mp3car.com/ProductDetai...Show=TechSpecs
    I would be getting rid of the bezel hopefully, and just mounting the screen in the dash. however i don't know that dimensions of just the screen.
    Or would it be better to go with the 7" and make some type of backing plate?
    Jun 2006
    I guess i just saw this
    Viewable area (L x H) 6 7/8 x 4 1/8
    That looks like it will fit perfectly height wise, but with a bit of extra room width wise. Is it feasible to remove the screen from the enclosure, and just use that?
    Jun 2006
    Bump for info on removing the lcd from the casing.
    Jan 2008
    most will fabricate the casing into the dash, and that would make the monitor bolt right up.
    Jun 2006
    Quote Originally Posted by soundman98 View Post
    Do most people simply mount the display "as is" behind the dash?
  1. 2005 Tacoma GigaByte GA-G41M-ES2L build
    By VegasGuy in forum Show off your project
    Last Post: 04-02-2010, 09:45 PM
  2. First Car PC, going into a 96 Chevy Tahoe
    By drhart4000 in forum Show off your project
    Last Post: 08-07-2009, 10:53 AM
  3. First CarPC Build
    By Badams in forum Newbie
    Last Post: 06-08-2009, 11:22 AM
  4. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  5. Aux Input for my 2004 Chevy Colorado
    By soquickwitit in forum General Hardware Discussion
    Last Post: 08-03-2005, 02:33 PM
