Results 11 to 20 of 25
Thread: Newb: Double Check Me Please!!! (Anyone)
  1. #11
    Elsewhere
    Quote Originally Posted by theonlykid View Post
    I would stay away from anything with the 775 socket if possable. Yeah they are much cheaper CPU's but the 775 is a desktop CPU socket. They dont make any mobile procs for that socket.
    So?
    That means 65W TPD on just the processor. That is a ton of heat to get rid of.
    65w TDP is NOTHING for a CPU. There are CPUs on the marked that have twice the TDP and have been used in vehicle installations.
    There are plenty of power solutions for a CPU of this power. AS long as it is adequately cooled, it will work just fine.
    How about the Wiki?
  2. #12
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    the hottest my cpu as shown is 100f on a 110 degree day and thats with no cooling other than the cpu fan, on a 3 hour trip stored in the trunk of my car. You have nothing to worry about there.
    Live mp3Car Facebook Chat
  3. #13
    Jun 2008
    Seattle, WA
    It depends entirely on the case in which the setup is put. A MoCoSo case doesn't have much airflow, so a 65w CPU is the max I'd put in there. I have a MoCoSo case with a 45w AMD 4850e, and it runs hot. I'm actually thinking about drilling holes directly above the CPU fan, I've heard that helps.
  4. #14
    Vendor - Mo-Co-So
    Nov 2005
    Kross
    Do you have a old MoCoSo case with the exhaust and ventalation directly across from each other or one of the new ones with the intake and exhaust offset?
  5. #15
    Jun 2008
    Seattle, WA
    The older one, 3rd generation I believe. Purchased 10/16/08.
  6. #16
    Sep 2009
    Seattle, Wa
    sooo....
    how bout this one?
    http://www.pcconnection.com/IPA/Shop...ci_sku=9520352
    basically the same thing but cheaper.
    sounds like the heat won't be too much of an issue. i am going to mod a box for the cpu myself, either by fabricating thin sheet metal or gutting an old game station box. either way i plan on giving it a "swiss chesse" design to ensure adequate air flow. time to pull the trigger on this soma*****!
  7. #17
    Sep 2009
    Seattle, Wa
    Quote Originally Posted by Sonicxtacy02 View Post
    i have this mobo... best one i've ever used by far
    1)i believe it has one pci-e... thats it
    2)no processor, i use the e8400.. 3ghz. with 2gig ram and a 2.5 sata drive i can run the system bare with a m1-atx
    3)if you're going to use a pci video card this board wont work for you at all
    thanks bro. what are my alternatives to pci video cards. video is not a high priority for me though it is an option i would like to include. it just doesn't need to be top'o'the'line...
  8. #18
    Elsewhere
    If you want decent video, look for a board that has an nVidia chipset & onboard video.
    honestly, a PCI or PCI-E card of any sort is a major hassle in a vehicle. The normal bumps & vibrations of every day driving can cause them to work loose.
    Ever had a PC shipped to you and cards come loose in shipping, causing you to open the case and reseat them for the PC to work?
    Now imagine doing that on a semi-regular basis (weekly, bi-weekly, monthly or so)....
    Talk about a PITA.
    How about the Wiki?
  9. #19
    Woodbridge, VA
    Blog Entries
    32
    the built-in video is dvi-i.. very very high quality. I'm not running any high end games or anything so i dont have a benchmark but for in card video its just fine.
  10. #20
    Sep 2009
    Seattle, Wa
    im sorry, the built in video on what?
  1. 8 inch Widescreen LCD in double Din
    By Dimlow_UK in forum LCD/Display
    Last Post: 11-06-2007, 07:31 AM
  2. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 02:19 PM
  3. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  4. Final Double Check for Install
    By thunderdepot in forum Newbie
    Last Post: 10-07-2005, 08:46 PM
