What does everyone think of this setup?
This is just the main part of the brain for now but what do you all think?
JetWay JNC62K-LF AM2+/AM2 NVIDIA GeForce 8200 HDMI Mini-ITX Motherboard
AMD Athlon 64 1640 2.7GHz 45w CPU
2GB Mushkin 800 MHz DDR2 PC-6400 SDRAM
JetWay JNC62K-LF AM2+/AM2 NVIDIA GeForce 8200 Mini ITX Motherboard SPECS:
Brand JetWay
Model JNC62K-LF
Supported CPU
CPU Socket Type AM2+/AM2
CPU Type Phenom / Athlon 64 X2 / Athlon 64 / Sempron
FSB 2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge NVIDIA GeForce 8200
Memory
Number of Memory Slots 1×240pin
Memory Standard DDR2 800
Maximum Memory Supported 2GB
Expansion Slots
PCI Slots 1
Storage Devices
PATA 1 x ATA100 2 Dev. Max
SATA 3Gb/s 4
SATA RAID 0/1/0+1/5/JBOD
Onboard Video
Onboard Video Chipset NVIDIA GeForce 8 series
Onboard Audio
Audio Chipset Realtek ALC883
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Realtek 8211B
Second LAN Chipset Realtek 8111C
Max LAN Speed Dual 10/100/1000Mbps
Rear Panel Ports
PS/2 1
COM 2
Video Ports D-Sub + DVI
USB 6 x USB 2.0
Audio Ports 6 Ports
Onboard USB
Onboard USB 2 x USB Connectors @ 480 Mbit/s for 4 USB 2.0 Ports
Physical Spec
Form Factor Mini ITX
Dimensions 6.7" x 6.7"
Power Pin 20 Pin
Features
Features 2 x DB-9 RS232 Port
Packaging
Package Contents JNC62K-LF
Driver Disk
User Manual
Rear I/O Panel Shield
IDE/PATA Cable
SATA Cable
DVI to HDMI Adapter
CPU Cooler with Fan
AMD Athlon 64 LE-1640 CPU SPECS:
Brand AMD
Processors Type Desktop
Series Athlon 64
Model ADH1640DHBOX
CPU Socket Type
CPU Socket Type Socket AM2
Tech Spec
Core Orleans
Multi-Core Single-Core
Name Athlon 64 1640
Operating Frequency 2.7GHz
Hyper Transports 2000MHz
L1 Cache 128KB
L2 Cache 1MB
Manufacturing Tech 65 nm
64 bit Support Yes
Hyper-Transport Support Yes
Virtualization Technology Support No
Multimedia Instruction MMX, SSE, SSE2, SSE3, 3DNOW! Professional
Voltage 1.25/1.35/1.40V
Thermal Design Power 45W
Cooling Device Heatsink and Fan included
Manufacturer Warranty
Parts 3 years limited
Labor 3 years limited
2GB DDR2 PC-6400 SDRAM SPECS:
Brand mushkin
Model 991580
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 2GB
Speed DDR2 800 (PC2 6400)
Cas Latency 4
Timing 4-4-4-12
Voltage 2.0V - 2.1V
Heat Spreader Yes
Parts Lifetime limited
Labor Lifetime limited
