Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Another Newb Build... give me a hand here.
    Newbie rickhigginshtbr's Avatar
    May 2009
    Hatboro, PA
    Alright, this will be going into my 03 Grand Am and designed for show. How I want the motherboard / subs / amps displayed I already have figured out. But, the CarPC setup itself...
    Motherboard - Don't know the specifics, my old desktop... believe it has a 1.8 Pentium 3, retired it for the 3.4 P4 I'm using now.
    HD - Grabbin a solid state for the OS / software.
    Power Supply - Help me out here
    Monitor - Lilliput 8" touch screen in dash / Larger in trunk lid
    Soundcard - Help me here, requirement is great audio quality
    4-Port USB hub in front+rear
    GPS, Bluetooth, etc will be added on too... My main things that i'm unclear on are the audio and the power. What gauge wire would be run to the PSU?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by rickhigginshtbr View Post
    PSU is going to depend on some more specific details of your system. Each little component, even a GPS will add to the power draw. I personally used and M-2ATX a while back, moved to an M4-ATX and had trouble. I sue and Opus 360W and it's great. As far as gauged to the PSU I would run 4-8 GA to a dist. block. You will see the gauge of the PSU wires to be hooked up is rather small, 16-18G I believe.
    Sound is a whole other department. Personally I sue and OLD soundblaster live 5.1 card ($10-20) on ebay and the KX Custom Audio Drivers. I delivers some incredible sound. Some use onboard sound, some use large PCI Digital cards, I would search.
    May 2009
    Hatboro, PA
    Definitely going to want to use a PCI-based card for aesthetic purposes if possible.... And I may have that same card floatin around too.
    The PSU is only going to need 16-18 gauge wiring? Wow, would of expected more... Maybe I can run new power wire back from the front since my 0/1 gauge is going to be split between the 2 amps. 1 amp that i'm running now is an older 1600-watt Boss 4-channel that's powering my front components and 2 12's, but I want that to run all the speakers and add another amp for just the subs.
    Other items would be a slot drive dvd, wireless keyboard and mouse for tailgates with the regular monitor in the trunk. I may considering adding the fusion brain for more function as well, plus the odb2 goodies. 360 watt should be fine, right?
    Elsewhere
    Find out exact specs. You need to know to choose an appropriate PSU.
    Read the PSU-related FAQs: http://www.mp3car.com/vbulletin/advfaq.php
    First off, I suggest at least trying your onboard sound (assuming your system has onboard sound) and see if it meets your needs for audio.
    If it does not, then purchase a sound card. If you don't need a sound card, then you've saved some coin.
    PCI cards need to be secured in a vehicle installation, as the vibrations & bumps from normal driving can cause expansion cards to work themselves loose. If that happens while the PC is on, it can damage hardware, which I'm sure you don't want.
    If you're running 0awg for the amps, you might consider a distro block (if you haven't already) with a suitable wire (8-12awg is typical, depending on the setup) running to the PC.
    How about the Wiki?
    Jan 2008
    Quote Originally Posted by DarquePervert View Post
    while some of the smaller power supplies could probably run off 16 gauge, i would never run any smaller than 12ga for a m1-m3, or no smaller than 10ga for m4/dsatx(i ran 8ga for my dsatx). you can always fuse a larger line to take less current, so it really isn't hurting anything (except your wallet) to run 4/8ga to the power supply-- it just gves you room to expand later, without having to re-run power wire.
    for the sound cards, i had a sb audigy(i think?), and loved the kx project drivers, but ended up having issues with the pci extension it was connected with not allowing the system to boot(my install location had a max clearance of 2"). i ended up moving over to a usb sound card.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Nov 2007
    PA
    Quote Originally Posted by soundman98 View Post
    You guys missed what I said. I would run 4-9 to the the Distro block and then if you ever look at the Ground, ign, and acc wire coming off these PSU's the wires are tiny. I wasn't talking about the main supply from the battery.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Dougw133 View Post
    Ground should always be the exact same size as your power wire.
    Ignition and accessory is only drawing a few mA so pretty much any gauge wire is fine.
    Oct 2006
    if you're using a p3 motherboard, chances are there isn't any sata port and 99% of ssd out there is ide, better watch out for that.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    You can power those PSUs with, say, an ATX PSU, from the 12v molex connectors. Those molex wires are what, 16awg? And they work fine, for about 10"-15".
    In the car it's a different story, it depends on the PSU you're going to use. But it's impossible to run a 4 gauge wire to any of those PSU (for those who say you should use the same gauge for the ground) or anything bigger than 6 (make that 8) gauge from a dist. block. A connector for those huge wires would probably damage the PSU connectors.
  1. 10.4" Screen in 95 Accord.. First Build.
    By rob1218 in forum Show off your project
    Last Post: 05-22-2007, 10:11 AM
  2. Boot build
    By bates_10 in forum Car Audio
    Last Post: 11-25-2006, 09:52 AM
  3. Beta: CCarProject
    By BenjaminS in forum MacCar
    Last Post: 09-27-2006, 01:25 AM
  4. Design and build a winner!
    By Xterrian in forum General Hardware Discussion
    Last Post: 05-29-2002, 06:17 AM
