Results 1 to 10 of 11
Thread: Elantra GT Carputer
    Nov 2009
    Elantra GT Carputer
    First time installing a carPC, but been reading a long time on the forums and think I have most of the stuff figured out. I do have a few last minute questions...
    Equipment:
    ZOTAC ION Motherboard, DualCore Atom Built in Wireless and HD 5.1 sound
    1GB Ram
    250GB HD
    External USB DVD Drive mounted in center console
    Visteon HD Radio (Running Mitch's Cable)
    4Channel amp (Run all my audio)
    Xenarc Screen
    Ok So one question is, what is the best way to input the HD radio sound from the Visteon Box to the PC. Using the two channels for audio it only leaves the Mic-In rather than the Line-In. Does that matter as far as the input if it is Mic-In or Line in?
    Other question is what is the most commonly used, or should i say easliy integrated GPS Nav solution in RideRunner? I really like Streets and Trips, but from what I can read its not really intgrated well into the front ends.
    Also, I have been reading alot about volume control that is not directly run through the PC, like the Griffin option, due to having no control if the pc locks up. What kinds of solutions are there for this.
    Thanks again in advance
    Jan 2008
    all i can really help you with is the volume control-- there are two options:
    you can get a 1/2 din eq with a volume knob, and use that, or you can get some JL Audio CL-RLC controllers-- i did a review on them, though, i would be poor at determining if it will work for you, so it might be easier to search for the review and see if they will work for you.
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    whoo... another EGT carpc!!
    I'm using iGuidance and seems to be working rather nicely. Can't say anything about any other program as I haven't tried them.
    Looking forward to seeing your progress.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    What year is your Elantra? I got a 2004 Elantra GT that I will be installing on. If you need help, I got most of the planning done. I also have access to Hyundai shop manuals.
    Andrew
    Nov 2009
    I have an '05. Only snag Im running into as of now is mounting the screen. Any suggestions?
    Oct 2008
    Ontario, Canada
    Have you put a thought into using a Double-Din mount and hook the screen up to it?
    http://www.crutchfield.com/p_1209573...t.html?tp=3121
    My co-worker (Cmotors on here) managed to pickup his screen from a place that pre-mounted it to the doubledin adapter.
    sidenote - you guys should pop over to elantraclub.com and post up some updates there.
    Jan 2008
    bybyte.com (also available in the mp3car store) is the maker of the double din screen kit, though you might still need the mount from crutchfield to fill in a small gap around the screen.
    Nov 2009
    I bought a Metra kit, and have been trying to fit the screen in somewhat nicely and its not working. The screen is just a little to tall for the kit and just having a hard time mounting it and looking nice. I dont want to glue it, as I would like to put it back in its case if I ever decide to part the system out.
    Anyone have pictures of their screen mounted in the bezel?
    Oct 2008
    Ontario, Canada
    you may need to get your hands on a second Xenarc screen bezel and mold it into the Metra kit.
    I can't help you on a picture of screen mounted... as I took the install a little further with the 12" vertical screen.... which I need to re-do the mounting/bezel once the snow goes away. You can see a few pics of mine in my worklog - see sig
    Dec 2009
    http://store.mp3car.com/Preassembled..._p/mon-067.htm
    Won't this (standard Liliput EBY701 with Double din) work? Sargeants, your monitor is awesome!
  1. Replies: 37
    Last Post: 01-09-2011, 11:36 PM
  2. pioneer Avic F500BT - a $250 carputer ???
    By kafklatsch in forum General MP3Car Discussion
    Last Post: 11-09-2009, 03:25 AM
  3. Hyundai Elantra GT CarPC
    By cobase in forum Worklogs
    Last Post: 06-26-2008, 03:13 PM
  4. Replies: 6
    Last Post: 03-20-2007, 10:16 PM
  5. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 08:19 AM
