Does anyone know if my carputer would actually fit into the case I selected? I didn't see anywhere for add-on cards... heck, I am not even sure if the board itself would work.
a radio shack project case containing the phoenix soho. i'll find it.....
Response #8
Same thread, Response 242
5v and Ground all that's needed. I'd suggest either getting yur 5v from the molex. If you don't wanna buy another small power supply to give it 5v you could just hijack it from one of the hdd molex connectors. same with the ground you'll need.
i didn't do an external style phoenix soho personally. mines internal(using a LAN gaming cube so slots not an issue)
good catch on yur case.
here is a good size chart.
Well... I guess that answers that... lol
Back to the drawing board.
How bad of an idea is it to put a carputer in the trunk? The amount of space I have available is ridiculously limited.
micro and mini itx always mess me up(shouldn't micro be smaller then mini?!)
as long as you can get some air flow to the carpc, a limited space trunk install should also work
my carpc is under the passenger seat, mounted on a sheet of plexi...
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
Yea, that would make sense. However, there's a hole in your logic... dear... Soundman...
Micro ATX <--
vs
Mini ITX <--
Two different formats, so to speak. If it was Mini ATX and Micro ATX, you would have reason to complain. Though I'm not saying you're not allowed to complain anyway.
Cheers,
Kris
How Much Horsepower Can I have And Still Go To Heaven?
HID retro--100%
