Results 1 to 10 of 19
Thread: 2010 STi in-dash pc
    Jun 2010
    2010 STi in-dash pc
    Hi guys,
    Been toying with the idea of an in dash pc, and found out it's an old idea after googling for a bit. I already put together a parts list and am putting it up here to see if anyone knows some substitutes that will help me cut costs, or sees some obvious screw ups. This will be the third PC I've built from scratch, and I have a buddy that has built 20+ platforms who will be helping me troubleshoot and program it.
    My goal is simple, I want a setup that has:
    -GPS
    -Touch input
    -Decent sound quality
    -Data logging
    -gauge display (boost, EGT, etc)
    The setup will fit completely into the double din slot and retain an OEM appearance, as the only real reason to build this as opposed to buying a NAV unit is to gain performance data support.
    Current parts list for in Car PC
    Lilliput EBY701-NP/C/T 7" VGA Touchscreen with Backup Camera Wiring $165
    Joycon EX Steering wheel control adapter $40
    3 Axis Accelerometer $30 – currently out of stock
    AccessTUNER Race $FREE$
    Ride Runner $FREE$
    Google Earth NAV
    ADSTech instant FM radio tuner $36
    BU-353 GPS Receiver $36
    M2-ATX-HV 140W Intelligent DC-DC PSU $65
    AccessPORT $595 Already purchased
    SuperBeam Microphone Array $40
    ASRock 330 $255
    cirago BTA-3190 USB 2.0 Bluetooth Dongle $15
    Rockford Frostgate R300-4 $110
    Kingston SSDNow V Series 2x30GB $164
    1 GB Corsair SO-DIMM DDR2 800 $27
    Current estimate: $967 NOT INCLUDING AP
    This list does not include:
    Cabling
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I look at your pricing and wonder if this would not be a better idea for you as it would give alot built-in and includes most of what you are looking for, I am only offing this as a suggestion as i have no hands on with this. http://chinagrabber.com/double-din-7...r-pc-2270.aspx But in future i will be going this route and adding the extra's i want, which won't be much as most are built in just obd2 bluetooth dongle, tpms and software SNO
    Jun 2010
    Quote Originally Posted by SNOtwistR View Post
    Quote Originally Posted by fujiwara View Post
    -GPS
    -Touch input
    -[HL]Data logging[/HL]
    -[HL]gauge display (boost, EGT, etc)[/HL]
    Thanks for the suggestion, but I most likely wont go that route. As Stated in the OP, the only reason why I'm making the leap into the PC realm for this car is performance data. There is probably a way to hook up and OBDII and program it with the interface they're using, but from what I'm seeing now, the cost involved with making their setup log data would bring the cost to around $1100, and I have not seen any site that shows the quality of internals being used. Also, they're using an 8GB SSD and the option of coupling that with a 160GB mechanical HD is an additional $40. Unless I'm missing some stellar reviews on this model, I'm feeling like this is not the way to go.
    Elsewhere
    I guarantee that you won't be able to cram all that in your dash.
    Your best bet is to have the PC itself somewhere else (glove box, center console, under a seat, etc.) and have the screen in the dash.
    How about the Wiki?
    Jun 2010
    Quote Originally Posted by DarquePervert View Post
    I was thinking of atleast putting the optical drive in the glovebox for access. Thanks for the advice.
    Jun 2010
    oh and the amp is definately going under a seat of course
    Elsewhere
    At some point, I'm sure you'll figure out that the PC is, too.
    How about the Wiki?
    Jun 2010
    Yeah, but I still want to try to strip down the case and get it in there. I'd rather not have to worry about extra cabling and such. Although if the cabling proves to be easy, it would be beneficial to have it mounted out of the dash for dismounting it.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    If your main interest is performance data and you have a Subaru, you should do your data logging and dashboard display of ecu parameters using the Subaru Select Monitor (SSM) protocol. SSM will let you display Subaru-specific parameters in additional to normal OBD parameters and at a higher data rate. An ELM-based OBD reader and the DashCommand software won't be able to do that.
    I'd recommend a Tactrix cable and RomRaider software. This will also allow you to tune your car and reflash your ecu, when you get to the modding stage. There is a new SSM gauge display program called ECUTrackerSE that looks promising. Search for it in the Engine Management section.
    Jun 2010
    Thanks for the help! Now I just have to find a tactrix cable. RomRaider will have to wait, I have a cobb AP. I wonder if there is a way to link the Cobb cable straight to the in car pc. Then I'd have two components that I wouldnt have to buy.
