Results 1 to 2 of 2
Thread: A few questions before I start soldering...
    Jul 2010
    Hi all - hoping you knowledgeable folks can have a look at this diagram and answer a few questions:
    * does anything I'm planning look hideously stoopid on first glance?
    * I'm torn on trying to use my fuse box or direct-to-battery for the 12V constant source... basically cuz I'm scared of doing something stoopid and breaking my car. Any advice?
    * for all the places that I've written "to ground" should I just hook them up separately to the chassis? Or is it better practice to try and group the grounds together to a common place? Or to the negative battery terminal??
    Thanks in advance!!
    Raw Wave
    Nov 2009
    Merely commenting on the power distribution - and subject to better specific advice from others - I recommend straight from the battery.
    Why - the power is cleaner (not as prone to share path voltage drops & interference), and you provide your own protection (fuses etc) and cables (no strain or interaction with existing circuits).
    Whilst many things can be earthed/grounded anywhere, not so for "signal" carrying or interdependent stuff - they should usual have a single ground point. (To avoid ground loops and voltage offsets.)
    Make sure you ground cabling is at least that of the power feeds (ie, add additional engine-chassis-battery- cabling if needed).
    Where to ground? Aha! In "signal" cases, the most important aspect is probably the "single point".
    All grounds should be the same having HEAVY wires between the battery-, body/chassis, & engine/alternator-. Whether they are depends on load & cables/connections.
    I power my HU direct from battery+ & -, but I don't have any additional amplifiers etc. (If I did, I might ground all to the chassis instead.)
    When powering "through" something - eg, your 5V USB Hub thru the Carnetix - usually you would also ground thru that supply - ie, Hub is grounded via Carnetix.
    BUT!!! - since the USB might connect to other things that have local (chassis) grounds.... nah - I think I'll leave that for others. (Else I'd suggest it's a suck&see - if there are problems, maybe a ground-loop isolator, a stronger bond, a supression cap, moving the GND etc.)
  1. when i start my car, no sound
    By nickthegreek in forum General Hardware Discussion
    Last Post: 04-25-2008, 10:18 AM
  2. Ways to start a Car-PC
    By Sabbath in forum General Hardware Discussion
    Last Post: 10-01-2007, 02:02 PM
  3. Replies: 4
    Last Post: 03-28-2007, 03:49 PM
  4. Just about to start, but first a couple of questions
    By hell167 in forum General Hardware Discussion
    Last Post: 07-28-2006, 10:37 PM
  5. Been browsing the forum a while, have some questions before i start
    By nadroj81 in forum General Hardware Discussion
    Last Post: 01-31-2004, 05:13 AM
