Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Please review my proposed setup....
  1. #21
    Dec 2006
    Not sure if anyone mentioned the M2-ATX. Works fine for me. I have the i3-530 CPU.
    No regular software stresses the CPU to the max. Like Prime95 does. No need to overspecify the power supply for a burn-in tool.
    I got maximum 62 Watt primary (on the 12 V input) when running PTGui, a photo software that maxes out the four threads. i3-530 CPU, 16GB, 3x Intel SSD. If the efficiency of the M2-ATX were 85%, that would mean 53 Watt secondary on the rails.
    Power supply power ratings mean the output power.
    The i3-530 is the most efficient (power to performance) CPU or at least was half a year ago.
    I'd surely try the M3-ATX first if that is recommended by a reputable dealer.
    PS: Stay away from the Atom. It's already been outdated by years since it was introduced, let alone in a few years.
  2. #22
    Dec 2006
    Quote Originally Posted by jdmagoo1 View Post
    Does everybody else agree that the OPUS 360 is required for my setup?
    Because Im about to commit
    Seems at least a 3x overkill.
  3. #23
    Elsewhere
    Quote Originally Posted by JuniorGeezer View Post
    At this point, the resellers reputation is in question.
    Nobody is suggesting that you plan your power needs around an app to stress the CPU.
    Another reason not to go with the M3:
    The 12v output is dependent on the input amperage.
    so if you're hanging out enjoying the PC or showing off or whatever, you're draining the battery.
    The battery will drain a bit, and provide less amps across the board. The power output capability of the M3 drops, as well.
    And then what?
    Has anyone tested an M3 with a voltage drop so that it doesn't provide enough power?
    What could/would it do to the hardware it is powering?
    At the very least, the system will suffer a hard shutdown. Anyone who has used Windoze knows that this carries potential risks to data integrity.
    Is the Opus 360 overkill? Perhaps.
    But it's better to have power that you don't need than need power you don't have.
    How about the Wiki?
  4. #24
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Quote Originally Posted by DarquePervert View Post
    And then what?
    Ok,
    come on now... Per the m3-atx specs:
    11 - 16 volts = 6A (8A peak)
    So if your below 11V power drops..., but you can't get there because 11.2V is the deep charge shutdown threshold. Or am I reading the specs wrong?
    I'm not saying which PSU to go with -- as the OP didn't specify all his requirements. How important is space? or the selected case? He's already identified that this selection was mostly due to "future proofing", suggesting he doesn't do anything outside the *norm* (also suggesting he could go with a slightly less power hungry CPU). He hasn't mentioned cost of the different options (if that's a player), etc, etc. I was just noting that his list could be used to create a stable CarPC given certain perameters -- most importantly being not maxing out the CPU usage and powering devices smartly.
  5. #25
    Jul 2007
    Australia
    OK i decided to go with the M4-ATX, ah some of you may sigh but i think for the price i got it for and at 250Watts it will be fine. Considering Im readying on AVSforums that people are using the M3-ATX with the same setup as mine without issues.
    Anyway, with the lillput monitors are they commanded to turn on via the USB lead that plugs into the PC or do i need to setup a relay?
    Thanks again for your comments
    James
  6. #26
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    James
    The Lilliputs have auto turn on. Once power is applied to the unit, it will turn on the screen. You must turn that feature on under options in the Lilliput first. Only time you will need the relay is if you are not powering the Lilliput directly from the PSU. If you are, then simply connect the Lilliput to the 12V rail. To save 12V power though, I recommend just using the relay method and the supplied 12V regulator that came with the screen.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. Review: TouchScan OBD-II Software
    By mezz64 in forum The Review Palace
    Last Post: 10-26-2009, 08:53 PM
  2. my proposed laptop setup, any comments welcome
    By pwetherhill in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-28-2009, 10:45 PM
  3. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  4. FS: Selling my complete CarPc setup for $250
    By remarque in forum Classified Archive
    Last Post: 11-06-2006, 04:50 PM
