Results 1 to 10 of 14
Thread: Finally Starting My CarPC
    Jun 2010
    Vancouver, Washington, United States
    So it is decided, I'm pulling out my OEM Nav, selling it on eBay and using the funds to assist in my PC build.
    I'm posting here for some help on the components and maybe a slap in the face if I'm running in the wrong direction for some things.
    I want to start with the Zotac ZBOX HD-ND02-U Barebones system. *PURCHASED*
    SSD: Gotta go solid here, Crucial RealSSD C300 64GB*PURCHASED*
    RAM: Crucial 4GB 2x2GB Kit*PURCHASED* 2GB
    Optical Drive: Dell CA10N slot load blu ray drive *PURCHASED*
    GPS: not a ton of research done here yet. Input is welcome. What is the one most people go with that works really well?
    Display: Lilliput FA1011-NP/C/T 10.1"
    For power I was wondering if I could modify the OEM power supply for the ZBOX to accept DC input. Is this practice unsafe? Will I need a regulator of some sort?
    I know there is more stuff I need but this will be enough to keep me busy/get me started.
    If anyone else has purchased that monitor already, I'd like to know the dimensions without the bezel, if possible.
    Aug 2010
    In my opinion ATOM Are dead... AMD Zacate is the new generation for now... would buy this instead .. this is only my opinion Consider it or not..
    Jun 2010
    Zacate are the new hotness? This is certainly appealing and would give me a slot-load blu-ray, an extra 250GB drive, 2GB of RAM (one less thing to buy) ... you might be on to something. The extra cost seems to balance out. What's the performance difference between the two processors?
    At the moment, no one seems to have the ZBOX AD03BR-U in stock, barebones or not, that system is either not out yet or selling like hot cakes.
    Aug 2010
    Well first of all the new on board video is way better , plus it consume less wattage than the ATOM .. here's a test.. I am planning to get a asrock Motherboard ATM out of stock
    http://www.newegg.com/Product/Produc...-228-_-Product
    http://www.tomshardware.com/reviews/...-apu,2840.html
    Apr 2008
    Austin, Tx
    Quote Originally Posted by Ryven View Post
    Hmmmmmmmm....my Dell gives you all that and more, w/an Intel Core 2 Duo @ 2.13Ghz as well as SSD, which you're wanting, looking @ your build. I also have the cigarette lighter adapter so you can hard wire it in, if you're interested. It's DIN sized once you remove the plastic.
    Aug 2010
    Quote Originally Posted by whats77inaname View Post
    ISO your Power Consumption after we'll talk.... not comparable I'm pretty sure of that ..
    Apr 2008
    Austin, Tx
    Jan 2008
    that's not a standard 65w tdp c2d processor
    Apr 2008
    Austin, Tx
    Quote Originally Posted by soundman98 View Post
    My whole point is that it'll do what needs to be done w/aplomb, there are others using it w/out issue, and it is a robust and hardy machine. For an all in one setup, it's a pretty good option. But I'm not partial or anything *lol*
    As far as power usage: http://www.desktopreview.com/default.asp?newsID=453
    At idle, the system only consumed between 27 and 30 Watts of electricity. Even while decoding 1080p video, the computer used only 40 Watts of power.
    According to Xenarc, the 706TSA in my sig uses ~25w, so I'd have to say that the Studio fares pretty well.
    Jun 2010
    Well... I'm looking for a cost-effective mini that won't kill my battery when the car is off & as far as startup/shutdown goes, I can use something to control that, correct? I really like the Zotac ZBOX with the slot-load blu-ray drive. I tried to do some research on power consumption between the Ion ZBOX and the Zacate ZBOX. Does anyone have this in an apples-to-apples comparison? Price is a factor too.
  1. Finally starting my carputer
    By crzyjoker13 in forum Newbie
    Last Post: 01-16-2008, 11:11 AM
  2. starting my carpc setup
    By MuDvAyNeDude122 in forum Newbie
    Last Post: 04-30-2006, 07:10 PM
  3. starting my carpc setup
    Last Post: 04-30-2006, 02:58 AM
  4. Passport Fabrication, finally starting project
    By SurgResDocMD in forum Fabrication
    Last Post: 01-29-2006, 01:01 AM
  5. starting a carPC project
    By triton199 in forum Newbie
    Last Post: 01-12-2006, 05:58 PM
