ZOTAC NM10-A-E Intel Atom D510 (1.66GHz, dual-core) BGA559 Intel NM10 Mini ITX
$99.99 newegg
Patriot G Series ‘Sector 5’ Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM
44.99 newegg
Kingston SSDNow V Series SNV125-S2/30GB 2.5" 30GB SATA II Internal Solid State Drive (SSD)
75.99 newegg
Lilliput EBY701-NP/C/T 7" VGA Touchscreen with Backup Camera WiringCarNetix CNX-P1900 Ver.
159.95 mp3car store
2.2 Dual Output 140 Watt 12V DC-DC Regulator
99.95 mp3car store
Mini Wireless RF Keyboard & Touchpad Black
54.99 mp3car store
for a grand total of $535.86, I'm almost sure the wifey wont kill me about that price tag![]()
Cars
1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
Car PC
Planning
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
Cars
Car PC
Planning
Yes, the M4 would work. But it's a non-standard size so fitting it in a case could be an issue. You might want to look at an M2-ATX or even an Opus. People have reported EMI issues with the M2/3/4 power supplies. I have a 120W Opus power supply that I love, and I highly recommend it - but it's bigger than the M's, so careful planning is necessary when shopping for a case.
You can get 20 pin to 24 pin power converters all over ebay for cheap. I'm using one in my set up now...
http://cgi.ebay.com/20-p-24-pins-ATX...item43a2bb4e28
^i have one as well. while most hardware will run with only 20 pins connected, i chose to not take the chance for a couple bucks..
atom processors are a low power board type, so most likely, an m1, m2, or m3 will work. but be sure to check the power requirements by inputting everything into a trusted power calculator before getting one.
the m4 is a huge power supply for use with that board. that is not to say it is a bad thing, just pointing it out.
i started with a atom board, and a dsatx, and when i decided the atom board wasn't good enough, only needed to upgrade the mainboard/processor, and could stil keep my same psu..
really, if you have the space, and the budget for it, i would recommend a solution like the m4, or opus 120, or dsatx. though i prefer to recommend the opus, carnetix, and/or dsatx psu's over any m-series psu-- if you spend any time the psu section, you will see that there just seems to be more problems with any of the m-series power supplies. that isn't to say that these lines are trouble-free, they just have a lot less problems then any of the m-series..
HID retro--100%
So let me ask whats the deal with the Mini-Box picoPSU-120, world's tiniest 12V DC-DC ATX power supply unit (PSU)? Seems like a no brainer as far as power and size for me...
Cars
Car PC
Planning
the pico psu does not have any regulation on the 12v rail-- so it is not suitable for in-car use, as cars voltage varies from 10-15v--which means that your 12v rail will fluctuate that much... it also doesn't have a startup/shutdown controller built in.
HID retro--100%
Ahhh TY guess im back to the Opus or M's again ....
Cars
Car PC
Planning
Dont forget a 12v P4 - P4 cable, i know my M2 ATX didnt come with one which sucks
http://store.mp3car.com/P4_12V_to_P4..._p/cbl-014.htm
