Results 1 to 10 of 15
Thread: Carputer: 1969 Chevelle
    May 2011
    So I know the muscle car enthusiasts will hate me for this, but I'm going to put a carputer into the 1969 Chevelle I recently acquired. It's cheaper to put the electronics in it then restore it to original... (factoring in that I have lots of computers lying around)
    I know computers, and I have installed a speaker system or two, but I've never put a computer into a car attached to computer speakers and all wired to a battery and monitor etc...
    So, below is my proposed set-up...
    If you think there is something I should add for safety purposes (fuses, regulators, etc) would you let me know please.
    Also, if this won't even work the way it is, you can let me know that too since I've tried to read as much as possible before posting and this is what I've figured out... (probably way off though)
    Thanks in advance!
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Looks good, I use a different PS than the M4 but I assume it has a delayed output (12v) like mine. If so, this is a good place to trigger your amp if you do not want to use a toggle switch.
    Minor point, but if you do trigger the amp straight from the battery, don't forget to fuse that line nice & close to the battery just like your main 40amp line.
    I'm not sure how you came up with 40amps for the main feed because I don't know your amp but assuming you've done the math and it is correct; 8ga. wire is only going to be good up to about 10 feet of wire then it will be too light for the job. Even if it squeaks by in theory, you might be better off to use 4ga. right out of the gate to eliminate that as a possible problem when the system is done, also it will allow for future upgrades should you decide to upgrade the amp or add a second one.
    BTW, welcome to MP3car.com!
    May 2011
    Quote Originally Posted by PhilG View Post
    PhilG,
    Thanks for the reply!
    I will switch to 4 guage wire, I haven't actually purchased the wire yet so that's an easy fix and i'll probably be adding something else later this summer.
    I will fuse right near the Battery, didn't know that where you fused mattered...
    Should I maybe fuse before my computer too? If so what amperage? (i'm searching right now for this answer, I think i saw some stuff about it somewhere in the forums or FAQs)
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Don't forget there's USB cable coming from the monitor to the computer too (if you have touchscreen). AFAIK, just fuse it close to the source and you should be fine. However, you'd also have to fuse the monitor, if you power it from the M4ATX (plenty of power to do that, and it's clean, regulated power).
    Pictures of the car+dash+carputer locations, please!
    May 2011
    Quote Originally Posted by RipplingHurst View Post
    I'm running 3 USB cables to the front of my car so I can plug in monitor,flash drives with new music, etc. as the computer is going to be in the trunk.
    What amp fuse should I put in between the power supply and the monitor?
    I'll put a few pictures of the car up in a second... I don't have any of the dash yet, but it's going to be made with MDF board and wrapped in black to match the interior of the car...
    May 2011
    Here are some pics of the car, and a video of it idling (sorry it's sideways)
    Day 1: Paint still on.
    Day 2: Lots of paint stripped off.
    Video: Idling in driveway
    http://imageshack.us/clip/my-videos/204/mo5.mp4/
    Constant Bitrate meryan00's Avatar
    Feb 2007
    Indiana
    Are you planning on painting it also in your garage? or just the body work. Either way I think that it is awesome, can't wait to see this come along more.
    Dec 2007
    Danville, CA
    Quote Originally Posted by prostate05 View Post
    Very cool project!
    I'd use the same capacity as the one that came with your monitor cig ligther adapter, probably 5A or 10A. Don't remember which I use, I just took it from there.
    May 2011
    Quote Originally Posted by meryan00 View Post
    No way, I can't paint it, I'm bad at all that kind of stuff. I like to learn and try to get better at stuff, but I don't have the equipment to paint or the skills.
    However, I'm a soccer coach, and one of my players that I've coached for the last 6 years (ages 11-17) is just completing a senior internship at a bodyshop/paintshop so he's helping me do the body work, and then he's going to take it up to his shop and paint it and it gets him something to practice on. It's a cool experience for him and I. And it's a little cheaper to pay him...
    Btw, thanks RipplingHurst for the info.
    Dec 2010
    Hey prostate, what's the Chevelle got in it? I have a 72 LeMans that I'm restifying, and have an 04 GTO dash going in it that I want to set up a carputer in(very long project as I'm sure you know)
  1. 1969 Coupe Deville
    By MindDrive in forum Worklogs
    Last Post: 06-16-2010, 02:56 PM
  2. 1969 VW Bug - Planning First Car PC Please Advise
    By mi1stormilst in forum Newbie
    Last Post: 05-01-2010, 08:54 AM
  3. Install On 68 Chevelle
    By BradyF in forum Fabrication
    Last Post: 04-13-2007, 03:40 AM
  4. 1969 Dodge Phoenix
    By LowLux in forum Show off your project
    Last Post: 10-05-2006, 06:39 AM
