Results 1 to 3 of 3
Thread: Few questions on my soon to be carputer setup
    Jul 2011
    Ok First off, this is the computer i'll be using the<<Car PC Carputer MSI E350IA-E45, M2-ATX, 250Gb HDD, 2Gb>> <Search Ebay>
    & I bought a LIlliput EBY701. I've already installed the Monitor (pulled the cig lighter and tucked all wiring in the dash. so I Guess my questions are (And yes i've already tried searching)
    1. Does this paticular Carputer setup I purchased off Ebay, already have audio integrated and if not should I just use my old DVD player and run the audio through it?
    2.How exactly to you wire up a M2-ATX automotive grade smart power supply?
    -Thanks Again
    FLAC -zip-'s Avatar
    Ontario/Canada
    1. Looking at the back of the unit, yes it does have built in audio. You can tell by the 3 jacks. Probably also supports optical. I am nto 100% sure but it looks like it does.
    2. Manual LinkEither hook it up direct to battery, or battery to switch or ignition wire or ignition wire to switch. You have many options here.
    Sound Stage
    Eclipse|MTX|Infinity
    Jul 2011
    Quote Originally Posted by -zip- View Post
    1.Ok Thought so, I see RCA and 3.5 plugin's .....could make a harness to connect directly to the Acura's harness, or should just run the cord to the old single din dvd player and use it as an "amp" if you will?
    2.Cool thanks for the Link
  1. New Cam Setup questions
    By isomswim in forum Input Devices
    Last Post: 06-24-2011, 12:15 PM
  2. Questions on PC setup. Will it ever end!
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 09-17-2010, 08:25 AM
  3. few questions in setup
    By hoodlum in forum Road Runner
    Last Post: 09-27-2006, 05:57 PM
  4. carputer setup: rate my setup
    By Rykielz in forum Newbie
    Last Post: 08-12-2004, 01:44 PM
  5. Setup Questions ...
    By Robb@E.P.E in forum General Hardware Discussion
    Last Post: 08-29-2003, 06:35 PM
