Results 1 to 7 of 7
Thread: Wiring design/layout software?
    Dec 2011
    Question Wiring design/layout software?
    Hey everyone - I'm still in the early stages of building my CarPC, and I want to know if there is a good software program out there that will help me design the wiring layout?
    For example - I have the battery up front, the CarPC in the rear, the LCD panel in the dash, and the audio connectors need to go through the harness. I want a program where I can put little blocks that represent the PC or power supply or LCD panel or whatever, and then run wires to them with labels, so when I start wiring up the car I can tally up all of the different cables and make sure that I only have to pull my center console once to run all the wires.
    Perhaps something like Eagle CAD??
    Anyone have a recommendation? Right now I'm just using Paint.net and drawing it out. It is not ideal.
    Thanks!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    visio should do the job for you http://visio.microsoft.com/en-us/pages/default.aspx SNO
    Dec 2011
    I hadn't even considered that! Thanks! Looking into it, it looks like there is an Open Office version called Draw, -AND- even better a Google Documents version also called Draw, and they all seem to support the same things.
    Newbie deanb2's Avatar
    Sep 2008
    Calgary, AB
    Dia works ok for this, and it is free - https://live.gnome.org/Dia
    Dean
    Dec 2011
    I played around with the Google Draw app, and it doesn't seem like it'll work for me. For instance, I want to draw a line from one place to another, and have that line have a right angle in it... Can't do that in Google Draw - straight lines only. OR, if I want a non-straight line, it won't connect to the blocks, so if I move them they become disconnected.
    I'm trying Dia now - the screen shots look VERY promising!
    Constant Bitrate BADMOPAR's Avatar
    Mar 2007
    Sokolov, Czech Republic
    Maybe you could try this : https://www.circuitlab.com/
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
    Dec 2011
    I played around with Dia for 10 or 15 minutes yesterday, and it looks like it'll work perfectly
  1. Replies: 5
    Last Post: 05-04-2009, 01:40 PM
  2. Software to design box?
    By katit in forum Fabrication
    Last Post: 09-05-2007, 05:51 PM
  3. PCB layout software
    By EricE in forum Hardware Development
    Last Post: 05-16-2007, 07:36 PM
  4. Final Design/Layout Ideas
    By camsgs3 in forum Centrafuse
    Last Post: 02-17-2005, 07:05 PM
  5. opinion on PCB Layout software
    By abbas in forum Power Supplies
    Last Post: 05-24-2002, 12:07 PM
