Results 1 to 9 of 9
Thread: power to carputer for prep on desk
    Nov 2013
    Bristol, UK
    What is the best way to power my carputer including pc and lcd before I install it in my car (ac to dc power?)
    Any help would be great
    Andy
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    My test area is near my home PC , now I have a psu that is a bit overkill for the pc , so I made a wire with molex on one end and a double connector for both carpsu and lcd on the other end , works like a charm.
    you could also try a spare battery if you have one , or any ac adapter with 12 volts will do , just make sure it has enough amps output to supply everything your hooking up.
    here is a link to calculate the amount of amps you need according to the watts your setup draws.
    http://www.supercircuits.com/resourc...amps-converter
    View my worklog here
    Raw Wave
    Nov 2009
    I'd suggest a typical PC/ATX PSU.
    They can be free from discarded PCs else a few dollars from markets etc.
    They have a more than copious 5V supply and often a reasonable 12V supply.
    They are self contained; reasonably shielded, and have little output noise.
    Plenty of (parallel) outputs. Connectors can be used or cut off & wire-joined.
    A PC PSU will only put out 12V DC and won't vary like a battery or vehicle supply (eg, 12.6V; 8V - 15V etc) and it will lack a vehicle's electrical noise and spikes/transients.
    But it should be be fine for testing basic operation; power consumption; the presence of ground loops; etc.
    PS: Compared to a battery and charger - most chargers are very noisy. Some output high spikes (pulses) and others may exceed 15V. A PC PSU is lighter and probably safer and cheaper.
    Aug 2010
    I agree , a pc atx psu carries far less noise and are usually cheaper than a car battery too.
    the battery is an idea if you havent got access to one, its not ideal but will serve as an emergency solution
    Elsewhere
    A DC power supply that will output sufficient amperage is another option.
    Although an ATX PSU is going to be far cheaper.
    How about the Wiki?
    Nov 2013
    Bristol, UK
    Further to comments.....
    Thanks to all for comments, they are incredibly useful
    can I use the pc atx psu to input into a M4-ATX - to test the automotive psu as well?
    and power lcd?
    any tips on which wires to cut and use?
    Thanks again
    Andy
    Raw Wave
    Nov 2009
    You should be able to provide the ATX handles the 12V M4 load, and its wire gauge. (Internally they usually come from the same point.)
    Yellow is +12V.
    Black is 0V/GND.
    May 2012
    Grandville, MI
    You really need to look at the power supply. I was actually surprised when I was looking at an article that showed how to make a laboratory power supply out of a standard PC power supply that the +12 volt portion of a standard PC power supply supplies far less amperage than the +5 volt portion. Most power supplies will have ratings for each of its power rails and what they can output. You will also never want to run a PC supply without it being loaded down because it can burn up the supply. In the lab supply conversions they install 10watt resistors across certain lines. Apparently a standard PC supply has a load requirement on them to produce a smooth power curve. You also have issues with turning it on and such. Just look up "Converting ATX power supply to benchtop power supply" or something similar and you will find out a bunch of information. The PC power supplies supply 3volts and some negative voltages as well.
    Personally I have a Radio Shack power supply. It says it is a +12 supply but actually provides 19volts in a manner similar to an automotive supply. I believe the one I have is a 150 watt supply and I have had no issues running my car pc in the manner it was intended. I do have a on off switch I installed inline to reproduce the ignition switch lead to the computer to test it as if it was in car.
    I also wired a cigarette lighter style plug on this so I can add whatever accessories I want to add to try out.
    Rodney
  1. Setup Prep
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 04:02 PM
  2. Newb Carputer Prep/Install
    By KSN in forum Newbie
    Last Post: 03-04-2008, 01:43 AM
  3. Major Release Prep
    By jAyRoCkS24r in forum StreetDeck
    Last Post: 03-23-2007, 05:12 PM
  4. Carputer stuck at desk for how long?
    By Simy in forum General MP3Car Discussion
    Last Post: 07-27-2006, 07:48 AM
  5. Trunk Prep
    By binary.h4x in forum General MP3Car Discussion
    Last Post: 02-11-2004, 04:15 PM
