Results 1 to 2 of 2
Thread: Need ideas for ground loop noise
    Mar 2007
    Hello all, first post here. It's not carpc related, but pertains to hunting down noise.
    I have a 2003 Mazda6 with a factory non-Bose system. I'm using the Sylfex Auxmod for an auxiliary input (connects to where the tape deck should go). It uses a 3.5mm jack for input. With nothing connected to the auxiliary input, there is no noise. With just a 3.5mm cable connected, no noise.
    When I connect my XM receiver, there's some nasty ground loop alternator whine. Connecting my Harman Kardon Drive+Play iPod interface also results in some ground loop noise.
    To solve this, I went the easy way out with a ground loop isolator. I bought the PAC SNI/35 from Crutchfield, which AFAIK is the only GLI that used 3.5mm connections. It actually works great on the XM unit. But when using it in conjunction with the Drive+Play, it eliminates all low-end frequencies. Like there's a steep high-pass filter set for 150 Hz.
    I probably need to track the grounds down, one-by-one, but man is this frustrating. The Drive+Play is a really sweet unit (just received it as a gift last week) and it sucks to have to listen to either awful static or pretend I don't own a subwoofer.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Search on terms: ground loop or check the wiki for advice on this topic.
    Want to:
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Replies: 35
    Last Post: 08-04-2009, 10:29 PM
  3. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  4. Another Static and Hard Drive Noise Problem
    By dpom in forum General Hardware Discussion
    Last Post: 11-28-2005, 10:07 PM
  5. Got some humming/buzzing noise out of stock system
    By Bxscig in forum General Hardware Discussion
    Last Post: 07-31-2004, 03:39 PM
