Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Fitting an aftermarket headunit to a Ford Fiesta
  1. #11
    Low Bitrate dLockers's Avatar
    Jul 2007
    If you just want the facelift (mk6.5) fiesta stereo grab it off of ebay or a breakers yard. Cut the bars out with a hacksaw and file back, it looks like nothing has ever touched it.
  2. #12
    Dec 2005
    Yeah I'd be up for sawing the bars out and buying this new Sony stereo
    BUT
    It seems quite wide. It looks like the buttons have been moved up..
    [media]http://www.ford.co.uk/spg/getImage.asp?imageName=SPG_3_28_0_24156.jpg&filena me=radio_lrg.jpg[/media]
    Or is this not the facelift stereo, if not then please can you tell me what it is?
    Thanks for the help dLockers!
  3. #13
    Jul 2007
    That is the facelift stereo
    The dash has been rearranged but the headunit is still double din.
    Darren
  4. #14
    Oct 2009
    Cool
    Hey guys, just need to bump this topic as i also need a bit of help on this. Can someone please confirm these are the part i need for a Ford Fiesta Finesse 1.25 2004 54reg which i have a 3 way split cd player / radio 4500 model. Im looking to install a Sony ipod cd player. Thanks in advance!
    Description: http://www.fordpartsuk.com/shop/fies...el_rhd_350.htm
    Description: http://www.bluespot.co.uk/install/show_model.asp?id=84
  5. #15
    Mar 2010
    plymouth
    [QUOTE=vanquished;1351391]Hey guys, just need to bump this topic as i also need a bit of help on this. Can someone please confirm these are the part i need for a Ford Fiesta Finesse 1.25 2004 54reg which i have a 3 way split cd player / radio 4500 model. Im looking to install a Sony ipod cd player. Thanks in advance!
    im also interested in this!
    i have the three part stereo and am looking to fit a dual din non ford stereo in my 05 fiesta, was told by vospers that this part is not available! am well it clearly is!
    but how much of a gap will it leave? does the gap left equal the size of the double din draw? or is the gap much larger?
    andy
  6. #16
    Jun 2010
    hey i have a problem really hope someone can help
    i have put in a double din stereo into my fiesta mk6 but there is about a 1 and a half inch gap between the mounting and the ford stereo panel does anyone know how i can resolve this??
  7. #17
    Dec 2010
    Hi, this is the picture i was talking about, i want to fit an aftermarket radio in so that i can hook up a sub and amp and that, also so i can run my ipod and things, but this is the problem i have, i dont no what to do as with the radio being as bit as it is, how can i go about this? HELP PLEASE!!!
    Thanks in advance
  8. #18
    Apr 2011
    Hey - I have had the same problem with this head unit.
    I bought a new head unit today and the fitting kit to go with it.
    Removing this head unit is actually a lot easier than you might read elsewhere. Elsewhere people say you might need to use four 'keys' to remove the head unit, and that it is a two man job. I removed the head unit with two keys on my own.
    The keys should be available either from a Halfords store or from Ford directly - they are about 5.
    To remove this head unit, you need to insert the two keys on the left side of the head unit first (with the rounded end of the key outside the head unit, the most rounded edge facing in toward the centre of the head unit). You should be able to push them in far enough so that you hear a faint (but audible) click. You should feel a certain level of spring on the keys when they are in properly. You will then need to put one finger through each key, and push them outwards which will unclip the rear of the head unit. You should then be able to pull the left side of the head unit out of the enclosure by about 5mm-1cm. This will release the clips on the right side of the head unit, allowing you to do the same on the right side. Again, push the keys in until you hear a click, push the keys in toward the centre of the head unit, and pull. The head unit should then easily slide out of the enclosure.
    The bracket holding the wiring in the back of the 6000 CD unit is incredibly tight and has a clip brace holding it in. You can use fingernails (if you have them!) to lift the clip releasing the wiring socket. Remove the aerial socket and hey presto, the head unit is removed.
    If you have a 2007- Fiesta like me, the problem comes when you're actually trying to connect your new head unit to the power sockets. In my car, the wiring is very neatly but very annoyingly cable tied around the edge of the enclosure, meaning that the entire central dash unit needs to be removed and the cable ties cut, as the power sockets are underneath the enclosure of the central dash. I am still to figure out how to remove the central dash so if anyone knows it would be much appreciated.
    Halfords are doing 1/2 price installations at the moment so if I can't figure it out from where I am I might just have to book it in for a fitting.
    I know you posted this a while ago but am hoping that, in helping you... you can help me back if you've already solved this!
  9. #19
    Jun 2011
    Hi,
    Can anyone please confirm whether one loses the trip computer ability when installing an aftermarket unit into the fiesta?
    I would like to change my CDC6006 so that I can run an amp&woofer, but would like to be able to still use the steering controls and have the fuel economy&RDS on the converse display.
    Some double din suggestions would be welcome?
  1. stock headunit + aftermarket amp possible?
    By theheel in forum Car Audio
    Last Post: 09-11-2006, 02:12 AM
  2. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 10:41 AM
  3. Chrysler 300 -- need aftermarket headunit?
    By mikemccoy in forum Car Audio
    Last Post: 12-15-2005, 08:05 PM
  4. Replies: 0
    Last Post: 03-14-2005, 11:49 PM
  5. aftermarket headunit with RDS?
    By stevewm in forum Car Audio
    Last Post: 06-27-2004, 11:08 AM
