Results 1 to 10 of 19
Thread: Fitting an aftermarket headunit to a Ford Fiesta
    Mar 2007
    Dublin, Ireland
    Ok I've been scouring the internet for the past 2 weeks and so far I have had no joy. I got an early-'05 registered Ford Fiesta Mk6 a few weeks ago but I want to change the factory headunit for a new aftermarket one, mainly because I want to use my iPod through the stereo.
    Unfortunately, my Fiesta comes fitted with a Ford 4500 CD Player which, for those of you who are familiar with this model, splits the dash into 3 "sections" when the headunit is removed.
    Here's a picture of my dash.
    I've looked on ebay and other car audio websites and they sell adaptors for post September '05 Fiesta Mk6 models with a double DIN opening in the dash, but this is no use to me as the bars will restrict access to the headunit, etc.
    Is it possible to get a new dash from Ford which will fit my Fiesta but with an opening for a double DIN adaptor, or is my only option to cut the bars from my existing dash?
    I'm sure that somebody out there must have faced the same problem as me before. Any help is greatly appreciated. Thanks!
    Dec 2005
    I am in a similar situation to you at the minute, but i a mhaving trouble removing the dash to get to the unit.
    I have taken out the glove compartment to get to the screws behind it, undone the screws located below the heater fan switches, and removed the housing around the steering wheel to get the screws undone there, so all screw on the left, bottom and right sides have been removed, the dash still wont budge and theres nothing else for me to undo, can anyone tell me what ive missed?
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    crutchfield.com
    Apr 2007
    a usefull answer :P
    the part you want is the bezel for the fiesta with satnav...
    Fiesta MK6-Bezel Black (With SAT NAV)
    Part Number: 1148612
    Retail Price: £35.39
    checkout this link for how to get the bezel off http://www.ukfiestanetwork.com/index...howtopic=82664
    or you could take it into an installers and get them to do the work...
    There is also an adaptor available from autoleads, turning it into a single din unit.
    If you only want to get your ipod to work, then i think that you can just add the adaptor that ford supply to your current head unit (although you need to know the correct conections at the back of your current unit).
    Hope that helps
    Feb 2008
    Luck
    your in luck im replying to two people, firstly i just got my installment for a new head unit today. about getting the front facia off where your buttons to heat the front screen and rear screen are and there should be two blank buttons aswell that section pops out (use a flat screwdriver) and then there are two screws in there and then you will be able to pull the front off after disconnecting the wires to your heat and fan dial.
    and spidey my head unit was split into 3 aswell you need to go to halfords and ask for a ford fiesta 2002 onwards facia plate so you can cut the sections splitting the unit into 3 (those two thin plastic strips) and then you simply screw the facia into where the stereo currently is but obvisally you have to remove the unit first.
    Hope that helped
    Jun 2008
    There is a way to do it.
    You have to take the whole center dash out and the cut out the 2 bits of plastic that seperate the dash. If you go to any halfords and ask them, im sure they would print out the pages they have on theyre data base telling you how to do it. just tell them the make of your car and the situation your in and then ask them about the 'difficult fit' program on theyre computers.
    Hope this helps.
    Btw,, i was in the exact same situation to you yesterday,, i done all the dash conversion myself then took it to a car electrical garage to get it all fitted right.
    Dec 2005
    What aftermarket stereo with a front aux-in do you recommend?
    I'd love one that would fit the whole SatNav bezel (the large empty part)
    Rather than the usual one, as that would leave a big empty space
    Thanks in advance for any replies!!
    Low Bitrate dLockers's Avatar
    Jul 2007
    hi friend
    the bars simply cut out with a hacksaw
    Dec 2005
    Thanks dLockers for the reply!
    Your dash is awesome with that PC built-in!
    I'm going to have to look around for a big Sony stereo/SatNav to fit in there as I don't have the money to get a HD, 7' screen etc
  1. stock headunit + aftermarket amp possible?
    By theheel in forum Car Audio
    Last Post: 09-11-2006, 02:12 AM
  2. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 10:41 AM
  3. Chrysler 300 -- need aftermarket headunit?
    By mikemccoy in forum Car Audio
    Last Post: 12-15-2005, 08:05 PM
  4. Replies: 0
    Last Post: 03-14-2005, 11:49 PM
  5. aftermarket headunit with RDS?
    By stevewm in forum Car Audio
    Last Post: 06-27-2004, 11:08 AM
