Results 1 to 4 of 4
Thread: car pc or carputers
    Apr 2007
    car pc or carputers
    HI I have a alpine IVA-D300 flip up dvd/cd media player I've been looking at this car pc /carputer I would like to no if any one can tell me if i could put a carputer in my truck and use the alpine system I have maybe threw the Ai-Net plugin so it can be control with the alpine touch screen montor. I guess I'm thing something to convert a PC plug VGA output to Ai-Net plug input can any one help me is there and device that can do this if so please let me no thanks!
    Low Bitrate AltimateX's Avatar
    Mar 2007
    Wisconsin
    I'm no expert but I don't think it is possible. There are no drivers that would allow your comp to recognize the touchscreen ability.
    Elsewhere
    Quote Originally Posted by myjellio View Post
    In order to use your Alpine headunit as a touchscreen:
    - Break open the unit (that will probably grind this idea to a halt right there)
    - Reverse-engineer and convert the touchscreen to an interface the PC can use (USB or serial - You'll do some soldering here)
    - Write drivers for your OS to control the touchscreen (may or may not be necessary)
    The screen can be used as a display if you can output a COMPOSITE video signal (that yellow RCA jack) from the PC.
    Remember, though, that your screen was designed to play comparatively low-res images from a DVD or game console or broadcast TV signal. A PC resolution is much higher. That will make the image look like mediocre AT BEST. Text will be blurry and the image will likely look like ****.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    Please see this post: http://www.mp3car.com/vbulletin/newb...ere-start.html
    It will help to explain it in a bit more detail.
    Jan Bennett
  1. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 12:36 PM
  2. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 11:58 PM
  3. New to Car PC, here is my setup.
    By BarinaHum in forum Newbie
    Last Post: 11-06-2006, 09:16 PM
  4. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 08:13 PM
  5. PC wont boot while car runs
    By Empreez in forum Power Supplies
    Last Post: 11-30-2005, 05:25 AM
