Results 1 to 10 of 10
Thread: Newb: power question
    Mar 2007
    hello all. I currently am planning my car puter system and have a quick question. I have a Cap in the trunk for my amps, and i plan to put the carputer back there also. Could i run the + and - from the carputer to the cap?
    Thanks for the help guys
    Oct 2006
    Las Vegas
    Save yourself some heartache and run a seperate wire, fused at the battery. Yes you could, but with current drawn by the amps, the voltage drop that would ensue, and the electrostatic field of the cap discharging to maintain voltage steady...That circuit is just a little too busy to add an essentially unrelated load to it. Noise may also become an issue if you do.
    It's been a while...
    Aug 2006
    Bendigo/Victoria/Australia
    What he said and PC's dont drain much power so it's pointless to need a consistant amount of power from a cap when your Batt will be just as consistant. Have fun
    Mar 2007
    ok cool
    what sort of device do you guys recommend. what i mean is do i need a shutdown controller or DC-DC device. Im not sure i quite understand these devices, i have read a little, im not done completely, any info to clear up my confusion woul dbe awesome thanks.
    Elsewhere
    Quote Originally Posted by mygti02 View Post
    I recommend an all-inclusive PSU that has startup/shutdown control and battery protection functionality.
    Do you need one? No, not at all. You can use an inverter, as many people do.
    However, there are a number of advantages to using a DC-DC power supply. Read up about them on these forums.
    How about the Wiki?
    Mar 2007
    Quote Originally Posted by DarquePervert View Post
    how is this one?
    http://store.mp3car.com/M2_ATX_160W_..._p/pwr-015.htm
    Aug 2006
    i'm using an m2 it's very good. very simple and effective!
    Mar 2007
    Quote Originally Posted by HDTechnology View Post
    how did you go about wiring it up?
    Elsewhere
    If he likes it and it works well for him, he probably followed the directions in the manual.
    How about the Wiki?
    Mar 2007
    ahh thank you i was trying to find the wiring diagram for that. That makes everything so much clearer now, thank you!
  1. Replies: 6
    Last Post: 10-11-2006, 11:44 AM
  2. Car PC install newb install question....
    By SciFiFan in forum Newbie
    Last Post: 07-28-2006, 05:33 AM
  3. PW80 power question
    By Moneyfink in forum Power Supplies
    Last Post: 06-30-2005, 07:15 AM
  4. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-08-2005, 11:35 PM
  5. Power Supplies Specs Question
    By rushnrockt in forum Power Supplies
    Last Post: 02-19-2005, 01:34 AM
