Results 1 to 3 of 3
Thread: Newbie Saying Hello
    Mar 2007
    Wisconsin
    Newbie Saying Hello
    What a GREAT community! I started out trying to figure out how to get my gen-1 shuffle to feed into my factory radio. Guess where THAT got me! I'm in planning and purchase mode, but part of the fun for me is to re-use stuff I already have. I actually had an unused VIA Mini-ITX with 512 just sitting around. Throw in a Bose AM-5 speaker system (built in sub/cross), 600 watt amp, 40 gb laptop and 250 gb storage drive and I've got enough to be dangerous. I just purchased a Lilliput 7.5 and can't wait for it to arrive.
    I've read (AND SEARCHED!!!!) for some answers to the following questions without much luck:
    1. Anybody had their display freeze? Most comments just say it needs to warm up. It got to -46 this winter.
    2. Does ONSTAR use cell towers or Sats for GPS? I've got one of the older units that will no longer work in 2008 because analog cell towers are going away. If the stupid thing uses Sats instead of a cheesy cell tower to triangulate then maybe there will be a new source of cheap GPS hardware.
    3. I haven't had time to look yet, but anyone out there use a marine/ham radio in their ride? I'm trying to figure out how to tie it into the system.
    Thanks for the great site and information!
    Newbie Jive's Avatar
    Sep 2006
    Hampshire - UK
    Quote Originally Posted by binderbubba View Post
    Holy mother of .... that's a tad cold There should be recommended operational temperatures for the display units and I'd think that was probably a bit outside of the range. Can you or do you put heaters in your car?
    I thought all GPS was based on satellite technology, not analog cell towers?
    No idea on your radio question, good luck with your searching there and this is a great place for info
    Project install no where near started!
    Apr 2005
    Washington
    Yes, almost every winter! I either have to go towards more of an industrial system, or build a big enough garage to get my truck into. Probably cost me about the same to do either, but I could keep allot more electronic crap with a new garage!
    OnStar uses four different satellites to triangulate your vehicles location, but the system also utilizes terrestrial radio signals. It uses a form of telematics combining cellular, GPS, and onboard electronics (telemetry, diagnostics, & voice recognition).
    Cellular is provided through AT&T/Cingular, Sprint Nextel, and Verizon via their AMPS (Analog 1G) or CDMA mobile networks to communicate with the OnStar call center.
    Newer systems utilize a combined Vehicle Comm & Interface Module, while older had separate modules for cellular and GPS.
    The current OnStar cellular system is analog/digital-ready. Newer GM vehicles are equipped with dual mode, which allows the capability to use both in analog & digital systems, but by 2008, GM will switch over to an all-digital network.
    Word is that they have no plans to make upgrade packages for older, analog-only models. Looks like you might have to get a new car to go along with your new CarPC! There might be a component hack out later that might help if you have a two-module system as mentioned above?
    I have not, used to have CB eons ago, but not tied into PC. I am sure someone has tried. Try to search forum for answer.
  1. It seems 2 be that i'm a newbie
    By kieboom in forum Newbie
    Last Post: 04-05-2007, 08:57 PM
  2. Newbie, but not so newbie
    By comptech_69 in forum Newbie
    Last Post: 12-06-2006, 08:33 AM
  3. Newbie says hello everyone
    By atikali2000 in forum Newbie
    Last Post: 02-16-2006, 05:14 PM
  4. help a computer BUILDING newbie out....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-11-2004, 04:39 PM
