Results 1 to 10 of 10
Thread: '06 350Z first carputer
    May 2007
    Hi everybody,
    I'm very new at carPC stuff, but old with cars and computers alike. But i still do have questions just like anyone else.
    Heres what i'm thinking about doing, i'll break it down piece by piece and would love some negative input, and some positive too.
    Car:
    2006 350Z enthusiest 6MT
    Stock Battery and alternator
    Millage - 13,000miles
    Motherboard - iGoLogic MBI3899-F Socket 478 Intel 945GM mini ITX
    Processor - Intel Core 2 Duo T7200 Memrom 2.0GHz 4M shared L2 cache socket M
    Power Supply - OPUS 150 watt DC-DC power Supply SFX.1215
    Shutdown controller - CarPC Pro v2.5d - The Advanced ATX Power Controller
    CPU cooler - Dynatron I61 40mm 2 Ball CPU cooler
    Memory - A-Data 2GB (2x1GB) 240-pin DDR2 SDRAM DDR2 667 (PC2 5300) dual channel kit desktop memory
    Display/Screen - Mp3Car TRANS 7 VGA (sunlight readable)
    Hard Disk Drive - Western Digital Caviar SE WD3200JB 320GB 7200RPM 8MB Cache IDE Ultra ATA100
    Hard Disk Drive cooler - SYBA CL-HD-FS02 Aluminum HDD cooler
    CD/DVD - Sony Black 2MB Cache E-IDE/ATAPI Slim DVD Burner @ 8X
    Amplifier - JL Audio 500/5
    Subwoofer - JL Audio 10W3v3-2 (300W)
    Headunit - Kenwood DDX6019 (6.95" w/DVD/MP3/VCD/WMA...)
    Amplifier rack & Subwoofer enclosure - Zeneclosures
    This is all that i have written down on my notepad to this point, after looking and searching for about 2 weeks now.
    Now for the big question, is that power supply enough to do the job?
    What i'm trying to do here is build up the quickest/fastest system with alot of space and flexibility, hence the DVD headunit, so the passenger can watch a movie and i can view my navigation for directions, simultaniously.
    As far as mounting and placement goes, i'm planing on placing the whole system on a custom made rack behind the driver seat where the optional Bose subwoofer normally is, which i do not have in my car. The screen will be in a 2003 Cubby. Subwoofer will be placed in a Zeneclosures box, with the amplifier on the box with an amplifier rack.
    I would really appretiate some input, be it negative or positive, since i don't want to go the wrong route.
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    what you doing that needs so much processor power... if nothing special, what you're getting is overkill...
    and your whole idea stinks!!! (negative input)
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Well that was interesting feed back...
    Perhaps saying...for just GPS/mp3/video you don't need that much cpu...unless you have some fancy eyecandy to run.
    There are power supply calculators in the hardware section (I believe...just search).
    Of the top of my head I think the 150 may be a bit lite on power especially with the full size HD.
    Also the OPUS has a built in shutdown controller...do you need a second one?
    What video card will you be using? On board video?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Regarding to CPU power; If the choosen PSU can power you whole system, that is fine. There is never too much CPU horse power.
    Since you already has the Opus, there is NO need for the CarPC Pro. The Opus already can do almost all the function that the carpc pro has.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2007
    Quote Originally Posted by farobaba View Post
    Hi everybody,
    So are you going with the flip up door or doing the GPS panel hardware from Nissan?
    May 2007
    Dennis - Thanks alot, i'm looking for stealth + carmeet showoff quality. I thought i might need the extra bit for future upgrades.
    DodgeCummins - Thanks for ur advice, i will be using the onboard video card which has shared memory of 256MB i believe. I guess i didn't do my homework to find out that the OPUS has a shutdown controller too. Which DC-DC powersupply would u recommend?
    MatrixPC - thanks for ur comments, so i guess i don't need a seperate controller.
    Z1Truth - I have a 2006 and i will be using a 2003 Cubby since it doesn't have gear reducers and all the extra stuff, which means lesser cutting and hacking.
    Ok guys theres a guy selling this system, what do u think about this, should i go for it?
    Included with sale:
    -03 Nav cubby with 7" lilliput touchscreen monitor already fabbed in
    -carputer
    -1gig ram
    -2 hard drives, one with windows and a seperate 80gig hard drive
    -gps and gps software
    -slimdrive cd/dvd burner
    -power supply with auto on-off feature so no need to manually turn carputer on and off
    -4 guage cable with distribution block providing power to the motherboard and a separate car amplifier
    -custom built amp rack that fits snugly in the drivers cubby hole and has removable pieces for easy maintenance on your components
    -all cables necessary to hook everything up
    -windows xp professional
    -Included GPS antenna and software
    -BIOSTAR TForce6100 Socket 754 NVIDIA GeForce 6100 Micro ATX AMD
    -AMD Sempron 64 2800+ Palermo 1.6GHz Socket 754 Processor
    -M2-ATX smart power supply
    -Max ram is 2gb
    -HD with windows is 5gb...other HD is 80gb
    he wants $1,000.00 + shipping
    Jan 2007
    OK there farobaba........you better do some more home work. The 03 door will not fit your 06 Z. They made the 06 cubby door BIGGER! I know, I have a 06 and I tried and died. Sorry to break it to ya. Go to my350z.com and to the audio/mod section and search.
    May 2007
    Quote Originally Posted by Z1truth View Post
    yea, i am on my350z.com and i did the research, what i found out was that, it would fit with a little gap.
    Oct 2000
    DFW area
    You guys get a door?
    Must be nice.
    Jul 2007
    Could this center panel and finisher work for the 06 w/o NAV???
    http://www.trademotion.com/partlocat...06&catalogid=2
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  2. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 09:32 AM
  3. 350z Carputer - any ideas?
    By PK! in forum Newbie
    Last Post: 12-07-2005, 03:53 AM
  4. New carputer project started - 350z (56k beware)
    By StutterinJ in forum Fabrication
    Last Post: 05-22-2005, 08:45 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
