Results 1 to 10 of 10
Thread: Aopen MiniPC DVI Connector
    Apr 2006
    Okay I have the AOpen MiniPC. It comes with an adaptor that converts dvi to vga (this http://www.pacificcable.com/Picture_...taName=DVIHD15 ) I don't have enough room for the connector and vga cord so....
    Can I... Plug this product http://www.pacificcable.com/Picture_...DVIIDL-MF-14IN straight into the aopen pc, then use the supplied dvi to vga connector, and then plug my lilliput into that without signal loss and with compatability?
    Apr 2006
    Noone?...
    Can I go
    dvi>>>right angle dvi adaptor>>>>>>>dvi to vga adaptor>>>>>>>>>>vga?
    Will the middle dvi adaptor still send the signal correctly?
    Elsewhere
    It's arrogant to expect an answer in a mere 5 hours on an internet forum.
    Yes, that should work.
    How about the Wiki?
    Jan 2007
    If you only have a DVI out on your computer system....can you just use a DVI to VGA (for a xenarc 7" screen) adapter????????????
    I was told you had to have a expensive box to convert the digital signal from your computer to a analog signal to go into your monitor?!?!?!?!
    What is the right way?
    Elsewhere
    No, you don't need an expensive box or anything.
    Hell, you don't even need the comparaively expensive cable that the OP linked to.
    How about the Wiki?
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Heya
    I ran into the same space problem with my Aopen i945Gtt-VFA motherboard, what your thinking will work.
    I attacked it a little differently I used DVI male to VGA male cable and then a female to female vga adapter to connect my Lilliput monitor to the VGA on the cable (all purchased from Pacific Cable). Note you can purchase a DVI male to VGA female cable but thats a custom very expensive cable (as least it was every where I looked).
    I went this route because the supplied Aopen DVI to VGA adaptor is rather large and only has one screw connection on the DVI side this did not make for a very good connection (at least mine did). The female to female VGA adapter is tiny in comparison has to two screw connections on either side.
    P.S
    Good luck with the Car PC
    Registered User
    I did the same as kimota and it work great
    Jan 2007
    Quote Originally Posted by DarquePervert View Post
    Thanks Darq! I gotta say you guys and this website are the GREATEST!!!!! I am learning soooooo much!
    Apr 2006
    Thanks guys. I went with the dvi male to vga female cable instead of adaptor. http://www.tigerdirect.com/applicati...&sku=P511-3800
    Hopefully it will give me the room I needed.
    Nov 2006
    Howdy,
    You should be fine but the cable you mentioned is only 6 feet, I needed a long run at least 20 feet got a 25 footer worked great.
    But unfortunately the length I needed was only available in DVI male to VGA male but the female to female vga adaptor is tiny .
    P.S
    Kalt I owe you a BIG THANK YOU, man did I RAPE your thread on the i945GTt‑VFA I feel like I owe you money or something
  1. 2001 Honda Civic Aopen Pandora MiniPC
    By Quack in forum Worklogs
    Last Post: 07-23-2010, 05:01 AM
  2. FS: Aopen Pandora minipc
    By iafireman_emt in forum Classified Archive
    Last Post: 10-25-2006, 09:45 PM
  3. FS: Aopen Pandora MiniPC carputer plus extras
    By Quack in forum Classified Archive
    Last Post: 08-08-2006, 07:23 PM
  4. FS: Aopen 915-B Pandora miniPC small NEW in box
    By kickercivic1 in forum Classified Archive
    Last Post: 02-21-2006, 08:55 AM
  5. Aopen Pandora MiniPC (Full System) and Carnetix P1900 P/S
    By cybrchaddy in forum Classified Archive
    Last Post: 02-20-2006, 02:57 PM
