Results 1 to 9 of 9
Thread: Finding -5V with M2-ATX PSU - Noob requests help please
    Newbie tazmaniandevil's Avatar
    Oct 2006
    Stirling, Scotland; UK
    I need to install another mobo because I now have a Silabs USB radio which conflicts with the touch-screen no matter where I plug them in. I can have one or the other which is not much good really.
    The board I have is an upgrade orphan, and not new. The board is an Asus P4B533-VM running a 2.4GHz CPU and 1Gb RAM. I can get everything working no problem indoors using a mains PSU, but when I plug it in to the M2-ATX PSU the fans spin, but I get "No VGA Signal" reported on the screen.
    One of the chaps on the digital-car.co.uk forum thinks the board may need -5V which the M2-ATX does not supply.
    My electronics knowledge is non-existent, so I don't know whether any -ve will do or if it needs to be corrected 5V via some kind of rectifier.
    Some days - it's hardly worth chewing through the restraints
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    I can't be 100% certain on this, but when I looked it up, you should only need the -5V if your system has ISA card slots. Can someone else back this up?
    Oct 2006
    B0ll0x - back to square one then.
    If I plug in a mains PSU, it all boots and runs like a dream. If I plug in the M2-ATX however, the fans spin, but all the screen says is "No VGA Signal" with no POST beeps etc.
    The M2-ATX seems to be OK because it still powers the epia board OK.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by tazmaniandevil View Post
    spins the fan with no POST and no beeps on an m2 usually means ur over its power limitation.. remove all your exteral stuff and try it
    Live mp3Car Facebook Chat
    Oct 2006
    I tried it with everything disconnected, even the hard disk. I used an online power calculator which came out at 114W. The M2-ATX should kick out 180W according to the manual. It is driving me nuts.
    Woodbridge, VA
    Blog Entries
    32
    m2 is 160w... and while i'm thinkin about it.. do you have the p4 connector connected?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    you may be 114W but you "probably" overload one of the power rail.
    -5V is use only if the system has ISA slot like neo already said.
    Compare power rating on each rail of the desktop psu and see the different.
    You can also try using the M2 to power just the mobo. And use the desktop PSU to power the HD/DVD to see if that work.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2006
    CT
    This might be useful:
    M2-ATX power distribution specs:
    12V = 96W
    3.3V = 26W
    5V = 40W
    Found this info on one of the power supplies thread, im sure if do a search you can find it.
    Oct 2006
    Quote Originally Posted by MatrixPC View Post
    Thanx for all the suggestions folks - much appreciated. No ISA slots on this board, so I assume the -5V thing is not the problem. I do have the P4 connector connected, and have tested the outputs from the M2 and it all seems to be OK.
    I tried the "mobo only" with the M2, but got the same result. The fekkin thing just won't fire up. It's a p1sser because I can't use the Silabs radio with the epia board.
    The performance of the epia board otherwise is fine for my requirements..... I just want to use my Silabs radio so I can get rid of the head unit and the sh1tty cassette adapter.
    If the M2-ATX is overloading, which was my first suspicion, I wish the board would power up on it's own because I read somewhere that you can use more than one M2-ATX in parallel.
    The whole thing is driving me crazy.
  1. New PicoPSU-60 (6-26vdc input)
    By ik632 in forum Power Supplies
    Last Post: 10-03-2006, 12:18 PM
  2. questions about running +5v from psu in trunk to dash
    By mattress in forum General Hardware Discussion
    Last Post: 05-21-2006, 08:35 AM
  3. Standard Desktop ATX PSU Question...
    By lowspeedchase in forum Power Supplies
    Last Post: 02-15-2006, 10:04 AM
  4. 24VDC in ATX PSU
    By Julian in forum General Hardware Discussion
    Last Post: 03-18-2001, 06:26 AM
  5. KeyPower DC-DC ATX PSU
    By katnip in forum General Hardware Discussion
    Last Post: 08-08-2000, 02:16 PM
