Results 1 to 3 of 3
Thread: Heatsink weight -- problem?
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    This is kind of a newb question, so it seems appropriate here.
    I want a quieter Socket A cpu fan than the stock AMD one. I have a ThermalTake Volcano 12 sitting around, and it has a nice copper heatsink and variable fan speed. But it's kinda heavy. Is this a problem in a car where it'll get jostled a lot?
    Elsewhere
    If the motherboard is mounted vertically, I could see it being an issue. If the motherboard is horizontal probably not.
    I use a 1U cooler (designed for a slim rackmount server) on mine. It's comparatively light, as well as very low profile.
    The compny I bought mine from no longer exists. Here's a comparable (if not identical) unit: http://www.cwc-group.com/so370lowprco.html
    How about the Wiki?
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I just had my commell LV-670 MB fail due to the weight of my low profile heatsink. The MB was visibly bowed from the weight. My MB is mounted horizontally and I did not take this into account, so good question and I will not make this same mistake with my new board.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
