Results 1 to 5 of 5
Thread: Question on powering a pc?
    May 2006
    Calgary, Alberta
    Which state is your computer in when the car is off? Are you fully shutting down, hibernating or standby? The only way it'll draw power from the battery is if it's in standby and even then you won't notice it unless you don't drive your car for a few days. So when you go on vacation, turn it off completely, otherwise don't worry about it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    I have my carputer always shutting down, but even then it managed to drain my battery over a 10day period. (snowboarding trip)
    I'm also interested in the solar panel option, especially since I'm looking to replace my mini-itx by a laptop which will stay in standby.
    '03 BMW 320d (E46)
    Carputer progress : [#----------]
    Gathering information ... currently using my phone connected through BT as carputer
    '99 BMW Z3 coupe 2.8
    Carputer progress : [-----------]
    No work done yet
    Oct 2004
    NY
    the problem with solar panels is they only supply a very small amount of power in a size panel that's reasonable for a car, unless your looking to do large solar panels they won't supply all that much.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    After your computer shuts down and "turns off" it still pulls some power on the 5v rail, this is why there's an LED on some motherboards (like my Asus boards). The only way to completely kill it is to either switch off power or use an intelligent power supply like an Opus or M2-ATX or something.
  1. Powering amps and car pc
    By red_parchel in forum Car Audio
    Last Post: 03-22-2007, 07:22 PM
  2. Powering tablet PC straight from cig lighter power?
    By Brib3 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-19-2007, 12:51 PM
  3. Car PC, Power and gas question
    By tryme in forum General MP3Car Discussion
    Last Post: 12-17-2005, 07:03 PM
  4. Question on using a relay for powering PC using remote wire
    By mattress in forum General Hardware Discussion
    Last Post: 02-07-2005, 09:19 PM
  5. dumb question. how do you turn on the pc?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 04-03-2001, 01:49 AM
