Results 1 to 9 of 9
Thread: multi source output to different screens
    May 2007
    london
    Cool multi source output to different screens
    Hello,
    I am newbie, so applogies if this has already been covered, but I could not find in the forumn.
    I am specing out a car pc and was wondering if it was possible to do the following.
    i want to be able to have multiple screens in my car, 1 at the front (flip out screen) and 2 in the back (headrests).
    What i was wondering was whether or not it is possible to have different items playing on each via the Car PC.
    For example, navigation at the front and Divx playing at the back or a divx movie at the front and a different one playing at the back.
    Is this possible?
    Also, if anyone has recommendations for a Car PC, screens, headunit etc, I would appriciate it.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    hi mistys77,
    the ability to display different things on each screen will depend on what you use for your computer.
    if you want to keep the smallest system possible, then you would be using onboard video (which will only have 1 video output, you can "split" the signal out with a VGA splitter but both screens will display the same thing).
    to make each display separate, you will need a video card with multiple display outputs. most video cards have 2 [DVI or VGA] outputs and 1 [S-Video] output, there are physically 3 outputs but you can only use 2 of them at the same time.
    a 2 output video card will be ok for you as long as the two headrest monitors can display the same thing. in this case you would hook your front monitor to one output, and hook the two headrest monitors to the other output (via a splitter).
    if you need all three monitors to be able to display separately, then you will either have to buy a triple or quad output video card (they are expensive) or if your system supports it, add a second [PCI] video card to give you another one or two outputs. another option would be to hook the rear monitors up to a DVD head unit (not attached to the PC), as long as the headrest monitors have multiple inputs, you can switch them back and forth between the PC and the HU.
    hope this helps, good luck
    May 2007
    london
    Smile
    Thanks.
    I will have to find a graphics card with s-video and dvi outputs. As long as the front and back have the different items playing that should be fine.
    thanks
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by mistys77 View Post
    Thanks.
    thanks
    PC is probably the way to go, but FYI, some laptops support dual heads. I don't know how common it is these days, but my Inspiron 8600 has duel heads.
    Mar 2007
    Lancaster Pennsylvania
    you could just use the onboard video, along with a video card with 2 outputs....
    so then you could display 3 different desktops.
    Newbie osa2's Avatar
    Jun 2007
    Belgium
    So, ones one got himself hands on a system (pc) with 2 video (vga) ports.
    How do I regulate that my navigation is on the primary screen and DVD playback happens on the external headrest monitor?
    I would like to have RR on my system I choose navigation I see everthing on my primary screen. I choose DVD playback. I still see DVD on my primary screen not on the headrest monitor.
    How do I configure this??
    Jul 2007
    software would regulate this. by default windows opens the screen to which ever you set as the primary or the last one you left the screen on. example: if you open up media player and move it to the rear screens, and close media player. WHen you reopen it they should open up in the rear screens. different front end software will allow you change this.
    My purpose in life... to do everything the wifey says too... or atleast thats what she tells me :P
    May 2007
    Boston
    Quote Originally Posted by keatonreckard View Post
    in any motherboard I've owned, when you install a video card the onboard video is automatically disabled (with no option to renable it unless the video card is removed).
    I have been building my own computers for years, and I have never seen a motherboard/BIOS which allows simaltaneous use of both onboard video AND a separate video card. (I'm not saying it doesn't exist, I'm just saying I've never seen or heard of one )
    Banned
    Jun 2006
    Totally true. Sometimes you even have to disable the Onboard video in the Bios in order for a different video card to even work.
  1. alpine dva-9860 pxa-h701 optical aux source
    By cougarz in forum Car Audio
    Last Post: 01-26-2006, 07:05 AM
  2. multi source audio integration via amps
    By theonlykid in forum Car Audio
    Last Post: 11-21-2005, 06:42 PM
  3. multi output video amplifier
    By NYCdesignkid in forum LCD/Display
    Last Post: 08-19-2005, 07:58 AM
  4. Aux-in Analog audio... will it output from the SPDIF on mainboard?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-07-2005, 09:57 PM
