Results 1 to 7 of 7
Thread: windows help
    Newbie lime's Avatar
    Jul 2006
    scarborough, Ontario
    windows help
    hey all
    i have tried searching but have not found what i am looking for
    ( I have found most everything else by searching, hence only 7 posts to date)
    i am trying to re format my hard drive on my car P.C
    i have an external usb cd rom drive and no matter what setting i put the bios at i cannot get it to boot from the cd.
    when i initally installed it i was using a cd drive connected via the ribbon cable.( internal)
    what i am trying to find out is how can i get the pc to boot off the external drive without having to take it inside and hook up the internal drive again.
    I am using a legit copy of windows xp pro and have tried it on my desktop and the disk is fine.
    I am using an MB VIA EPIA-M10000 1000Mhz Mini ITX mainboard
    any help or direction would be greatly appreciated.
    thanks in advance
    Emil
    Newbie tazmaniandevil's Avatar
    Oct 2006
    Stirling, Scotland; UK
    Looks like all you should need to do is select USB-CDROM as your first boot device in "Advanced BIOS Features". I take it you either have a supplied power for the CD-ROM?
    Some days - it's hardly worth chewing through the restraints
    Jul 2006
    Quote Originally Posted by tazmaniandevil View Post
    i tried looking for it but i don't think i have this feature on my mainboard.
    as for my cd rom it is powered off a separate usb port.
    ( i am using two ports for it . One for the data and the other for power)
    Elsewhere
    Every motherboard has an option to change the boot order. It may not be int he place where Taz specified, as every BIOS is laid out differently.
    Also, I believe that you'd have to select USB as the primary boot option in your case. There is a possibility that your motherboard does not have the ability to boot from USB, in which case you're going to need to hook up an IDE CD drive and do it that way.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    Are you sure that your CD rom doesn't require a dedicated power line and not just power off of the USB?
    That motherboard should have the option under the advanced bios features.
    It will be in the list with other USB options...like USB HDD
    Do you have a link to your CD-rom?
    Jan Bennett
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Download your MOBO (M10000) manual here.
    Page 3-9 of YOUR motherboard's owners manual.
    First/Second/Third Boot Device
    Set the boot device sequence as BIOS attempts to load the disk operating
    system. The settings are:
    Boot Other Device
    Enable the system to boot from other devices if the system fails to boot from
    the First/Second/Third boot device. Settings: Enabled and Disabled
    Swap Floppy Drive
    If the system has two floppy drives, choose Enabled to assign physical drive
    B to logical drive A and vice versa. Settings: Enabled and Disabled
    Boot Up Floppy Seek
    Set floppy seek during POST, BIOS will determine whether the floppy is 40
    or 80 tracks. Settings: Enabled and Disabled
    Floppy The system will boot from floppy drive.
    LS120 The system will boot from LS-120 drive.
    HDD-0 The system will boot from first HDD.
    SCSI The system will boot from SCSI.
    CD-ROM The system will boot from CD-ROM.
    HDD-1 The system will boot from second HDD.
    HDD-2 The system will boot from third HDD.
    HDD-3 The system will boot from fourth HDD.
    ZIP100 The system will boot from ATAPI ZIP drive.
    USB-FDD The system will boot from USB floppy drive.
    USB-ZIP The system will boot from USB ZIP drive.
    USB-CDROM The system will boot from USB CDROM.
    USB-HDD The system will boot from USB HDD.
    LAN The system will boot from network drive.
    Disabled Disable this sequence.
    Jul 2006
    D'oh ( slams head on desk)
    i bought it as a rtr assembly and never even thought of looking online for the manual.
    thanks to everyone who posted up i really appreciate your help.
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Vista experiences anyone?
    By Nomader in forum Road Runner
    Last Post: 01-10-2008, 09:01 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
