Anyone?
I have a M2-ATX, 2.5"HD, 512DDR Memory and SLIm DVD drive. would one of the setups work and what else would i need? right now i am only going to need it for music and movies. but would like to add GPS later. I f anyone has anyother suggestions leave the website address. thanks!!
http://www.mini-box.com/s.nl/sc.8/category.99/.f
Elite C7VCM
Elite C7VCM Mini-ITX Motherboard with VIA C7 1.5GHz Processor
- CPU: VIA C7 1.5Ghz
- Chipset: CN700
- DC-DC power on board, 12V in
- Board can power up to 2 x 2.5 or 3.5" drives
- Memory: SO-SIMM DDR 400MHz, max. 1GB
- Graphics: Unichrome Pro integrated
- Storage: 1* P-ATA
- Expansion: 1* PCI
- I/O ports: VGA, audio, 2* PS/2, 4* USB2.0, 1* 10/100MBit LAN, 1* COM, 1* parallel-port
- RoHS compliant
Price: $129.50
0r
Jetway Versa J7F4K1G5D
Jetway Versa J7F4K1G5D Mini-ITX Motherboard
- VIA C7 1.5GHz nanoBGA CPU (25w)
- VIA CN700 / VIA VT8237RP Chipset
- 1 x DDR2 Memory Slot supports up to 1GB
- Dual 10/100/1000 Ethernet Ports
- ATA133 and Serial ATA (SATA) IDE devices support
- VIA S3 Graphics UniChrome Pro AGP 8X onboard Video
- VIA VT1617A Audio
- 4 x USB 2.0 and 2 x COM (Serial) Ports
- 1 x PCI Expansion Slot
- Mini-ITX Form Factor: 170mm x 170mm
- RoHS Compliant
Price: $139.95
Anyone?
I'm not going to buy the Elite C7VCM but am looking at these two. which one is better. I have a M2-ATX, 2.5"HD, 512DDR Memory and SLIm DVD drive
- VIA VT1617A Audio
- RoHS Compliant
Price: $139.95
or
VIA EPIA M10000
VIA EPIA M10000 1GHz Nehemiah
- VIA C3 E-Series 1.0GHz Processor, Nehemiah core
- 1 DDR266 DIMM socket
- VIA Unichrome AGP graphics with MPEG-2 Accelerator
- 1 PCI
- 2 X UltraDMA 133/100/66 Connector
- 1 x FDD Connector
- VIA VT6103 10/100 Base-T Ethernet PHY
- VIA VT1616 6 channel AC'97 Codec
- VIA VT1622 TV out
- VIA VT6307S IEEE 1394 Firewire
Anyone care to help?
I did read the faQ. it doesn't answer my question. These are both good products. But i have heard that the Jetway has had problems with the m2-ATX. have they fixed this problem? and what are the Watts output of the Jetway Versa J7F4K1G5D Mini-ITX CPU and VIA EPIA M10000 CPU? If they have fixed the problem with the jetway and m2-atx i would buy that one because it has a 1.5GHZ where the VIA is only 1.0GHZ.
and whats the resolution output of these boards?
