Results 1 to 10 of 16
Thread: Water-cooling
    Mar 2007
    Eastern PA, USA
    Water-cooling
    Not that a couple computer fans in the trunk would really be that annoying, but has anybody tried water cooling a carpc with some hosing and a small radiator that brings in fresh air or air conditioning?
    Mar 2007
    why?
    You can buy fans that don't sound like jet engines taking off, such as the scythe fans which run at 20-30 dB (vs. typical case fans of 50-60 dB), which is more then sufficient for low power car systems.
    I have yet to discover any applications which my Via C7 1.5 system won't handle in a reasonable manner, and one scythe fan keeps it cool, even though it is buried under two inches of foam underneath the center seat in my truck.
    Jul 2006
    seattle
    watercooling in a carpc?
    we tried to make it as simple as possible,
    watercooling means more problem, leaking problem, etc etc etc.
    yes I used watercooling which is very reliable on my home pc, but I won't put it on my constantly vibrating car.
    I am very interested to see one though
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    I've watercooled for performance and silence - neither of which are relevent in the car
    May 2007
    if you air conditioned the radiator it would condensate and cause problems.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Been covered in detail... search if you like.
    TruckinMP3
    Read the FAQ!
    _
    Mar 2004
    Little Elm, Texas
    to all of them...why make it more complicated?
    leave your home PC ideals in the house.
    This is a car, think like you're going to be in a car.
    Jan Bennett
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Quote Originally Posted by RedGTiVR6 View Post
    Funny thing with that is, the whole entire water cooling idea came from automotive, hense the first, and still many water cooling setups using heater cores from cars.
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Elsewhere
    Water cooling something mechanical (like an engine block) is completely different than water-cooling something electronic.
    If the radiator hose pops off a fitting and spews coolant all over your engine, then you merely have a mess.
    If a hose pops of a fitting and spews coolant all over your computer, you've got fried com0ponents, a potential fire hazard and a mess.
    How about the Wiki?
    Nov 2004
    NY
    Thats true, the reason I always cancel it out is simply, water cooling will only bring the computer down to ambient temperature at best, this is good for in your house, cause you can have the radiator outside of the computer case so it can be cooler, rather then a HSF which not only has to deal with the heat from the CPU but the radiant heat of the compents which share the same case.
    I feel that in a car, it would still be hot being in the trunk, and if you put the effort to putting it in a spot that is cooler then the trunk, now its a hassle putting your computer in your car, or taking it out.
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. Water Cooling?
    By billybob3 in forum General Hardware Discussion
    Last Post: 04-17-2007, 12:39 PM
  2. Water Cooling
    By V6Stang in forum Hardware Development
    Last Post: 07-23-2006, 01:21 PM
  3. FS-PC Water Cooling Gear, Hard drives Misc Stuff
    By belezeebub in forum Classified Archive
    Last Post: 04-12-2006, 05:55 PM
  4. Water cooling proposal?
    By Vchat20 in forum General Hardware Discussion
    Last Post: 07-02-2005, 04:54 PM
  5. AC Water Cooling?
    By nFiniteTuning in forum Fabrication
    Last Post: 12-10-2004, 11:42 AM
