Results 1 to 5 of 5
Thread: Double Din LCD Unit
    Newbie wniemcow's Avatar
    May 2007
    Plantation Florida
    Double Din LCD Unit
    Walt
    Elsewhere
    Quote Originally Posted by wniemcow View Post
    My question: Can you buy a stand alone touch screen double din tv/radio unit and plug a Car Pc in it later as a AUX device? (Does that question make sense?)
    Yes, BUT...
    The video display will be of less-than-ideal quality. PC displays don't look too pretty on a TV, which is essentially what this unit is.
    Also, the touchscreen will not control the PC.
    Lastly, you need to output the PC display to cmposite video, which may or may not be an easy thing to pull off, depending on your hardware.
    Ok let me better explain: Take a unit designed for the DOUBLE DIN Slot - with touch screen - install that into dash. Build Car Pc - plug into the unit via aux or whatever the input might be. Is this possible?
    If your PC's video hardware can output composite video, then yes.
    I guess the better question is what do i look for in a unit?
    Ideally, a touchscreen with VGA input.
    where is red - i bet he knows
    Uhhhhh.
    Red is a she.
    How about the Wiki?
    Jun 2007
    You might also be interested in this thread Dual DIN LCD touchscreen monitor?
    There's a double-din touchscreen on the way from Panda innovations that I'm looking to buy -- read about that here http://store.pandainnovations.com/Articles.asp?ID=121
    DIGItonium
    Guest
    Not bad! It would be nice to get a standalone one and mod it with a real VGA screen. It just takes a bit more research.
    May 2005
    orange county, ca
    cool monitor
    that panda monitor looks great, i might have to go back to a stock dash
  1. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 02:19 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  3. double DIN LCD screen
    By nadir_s in forum LCD/Display
    Last Post: 01-03-2004, 10:21 PM
  4. LCD into double DIN
    By groovespacer in forum LCD/Display
    Last Post: 09-25-2003, 09:02 AM
  5. LCD size for double DIN ???
    By infinitiqx4 in forum LCD/Display
    Last Post: 04-14-2002, 09:28 PM
