Results 1 to 10 of 17
Thread: My WRX CarPC plan (feedback?)
    Jun 2007
    Hey everyone -
    So here's my plan for my WRX CarPC. Anyone have any suggestions?
    Gateway M405 laptop (already have) $0
    Carnetix P2140 $135
    Lilliput 619 or 629GL $251
    WRX bolt in double din kit $130
    BU-353 GPS receiver $69.99
    RoadRunner/IGuidance $99.99
    OR
    StreetDeck $199.99
    existing alpine HU (relocate to factory clock position)
    If the audio on the laptop isn't up to snuff, I'll go with a better USB audio card.
    I'm planning to mount the power supply behind the dash with wires up to the battery and the laptop under the passenger's seat. I'll set up the laptop to power on with car power and then to standby on car power off (either through USB or ASCPI wired to the laptop power button) and then hard power off after 2 hours of car power off. Audio out will go to the audio input on my existing alpine HU -- at some point I may swap it out for an amp.
    Thanks in advance for any feedback!
    -Justin
    Elsewhere
    Looks like you've got a good plan.
    If you haven't already done so, i'd make 100% certain that the power required by the laptop is capable of being put out by the Carnetix unit.
    It probably is, but there are some makes/models of laptops that use some unusual voltages or multiple voltages that make a Carnetix unit useless.
    How about the Wiki?
    Jun 2007
    Quote Originally Posted by DarquePervert View Post
    Great, thanks for the suggestion. The laptop takes 19VDC on a simple (barrel type?) probe, so I'm pretty sure I'm set there. I also found a docking station for it for dirt cheap so that might help (although it doesn't have a power switch which would be very nice).
    -Justin
    _
    Mar 2004
    Little Elm, Texas
    I'd also check out this thread for discounts on StreetDeck: http://www.mp3car.com/vbulletin/stre...ck-europe.html
    Jan Bennett
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    If you're thinking of relocating the HU up to the clock location, you may already know about this little gem, but just in case:
    https://www.subarugenuineparts.com/p...roducts_id=662
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Jun 2007
    Quote Originally Posted by cMags View Post
    Yep! Gonna order one from Jamie at subaruparts.com.
    -Justin
    Newbie Reble_45's Avatar
    Jun 2007
    Jacksonville, NC
    I LOVE YOU ALL. Never knew about this site till now. AWESOME. Thanks abunch.
    Signed,
    Nathan L. (AKA: Reble_45)
    I love my Wagon.... I love it so good.
    May 2007
    Just get a car adapter for the laptop and save 100 dollars.
    Also, if you get the bu-353 (proper name?) it comes with a magnetic base, which you can stick to the top of the head unit and it still fits underneath the OEM gauge hood. This puts it in a great place for GPS reception; raised, invisible, and in the center of the dash.
    Jun 2007
    Quote Originally Posted by oroboros_ARR View Post
    Wow, great suggestion on the GPS location. I'll definitely give that a try.
    I'm still going to go with the DC-DC regulator as I want to have the laptop go to hibernate gracefully when the car power turns off and come back on with the car power. The first half I can do with an inverter or car PS, but not the second. Also I'll get consistent power during engine crank, etc with the regulator.
    -Justin
    Jun 2007
    In case anyone is interested, here's my worklog: 2002 WRX CarPC
  1. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  2. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  3. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 09:56 PM
  4. Newbie Project Plan!
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 03-29-2002, 09:57 PM
