Well since it has a brick, I would use a Carnteix. Just like the mac folk do. Depending on what voltage it needs. The picture of the power brick was too pixelated to get the voltage/amp rating output to that power jack. If you find that, then you can narrow down which will work. An Opus is not the soltution, because it is much more than you need.
LinkBack URL
About LinkBacks
