Results 1 to 2 of 2
Thread: Couple of newbie questions
    Apr 2006
    I'm in the process of installing my car computer and I have two rather noobish questions.
    1) I ran a wire directly from my battery into a fused distribution block. The distribution block uses a screw to clamp down the wires which, in my opinion is essentially just a crimped connection. There have been a few posts stating that crimped connections aren't the best quality and are better to avoid. Is there an alternate way of connecting to a distribution block or did I just buy the wrong kind of distribution block?
    2) I'm assuming it's ok since a car's electrical system is a voltage circuit and will only draw as much current as the circuit needs but just to verify, it's ok to wire a 12V automotive 30amp relay directly to the battery, right? I know I don't need it but I just feel a lot safer with having a hard cut off between the battery and my Opus.
    Hofstader's Law: It always takes longer than expected, even when accounting for Hofstadter's Law.
    Cost [xxxxxxxxxx]xxxxxxx 169.126%
    Planning [xxxxxxxxxx]xxxxxxxxxxxxx 233.773%
    Implementation [xxxxxxxx..] 83.047%
    _
    Mar 2004
    Little Elm, Texas
    using that connection on the distro block is actually fine. It's more secure than a crimp connection that others are talking about.
    to the forums btw!
    Jan Bennett
  1. couple general Audio/video quality questions
    By Vladimer in forum Car Audio
    Last Post: 10-09-2006, 01:54 PM
  2. Couple Questions from a newb
    By bdavid12 in forum General MP3Car Discussion
    Last Post: 07-07-2006, 09:18 PM
  3. Newbie questions
    By DaveNagy in forum PhoneControl
    Last Post: 06-28-2006, 01:39 PM
  4. New to CF Skinning, couple of questions...
    By Crags in forum CF Skins
    Last Post: 03-24-2006, 04:38 AM
  5. Newbie questions
    By peecee in forum Road Runner
    Last Post: 03-02-2006, 01:48 AM
