Results 1 to 7 of 7
Thread: Neon Wires
    Jun 2007
    England
    Neon Wires
    Hello,
    What gauge wire do i need to extend the neon wire that runs from the neon light? I need the wire extending and if you could help it will be appreciated.
    Thank you
    Feb 2006
    Vancouver, BC
    what neon wire for what neon light? Thicker the wire the better but it depends on the power, the length, etc. Provide some more information.
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Right, but it depends on the voltage and current he's running.
    If he needs to extend the wires past the ballasts where the voltage is measured in the kilovolts and the current in milliamps, then the wires can't be very long (I would say no more than twice the current length) or else the neons would flicker or not work at all.
    Otherwise, the table posted above helps tremendously.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Do you mean a real neon light...or the backlight of a lcd display?
    In either case you need a wire with enough insulation to handle high voltages...no I don't know how high...but somewhere in the kilovolt range.
    Mar 2008
    Northern Ontario, Canada
    _
    Mar 2004
    Little Elm, Texas
    wasn't that already linked to in this thread?
    Jan Bennett
  1. Replies: 7
    Last Post: 04-10-2006, 08:11 PM
  2. Replies: 0
    Last Post: 03-25-2006, 01:12 PM
  3. Replies: 17
    Last Post: 02-17-2006, 05:59 PM
  4. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  5. Replies: 16
    Last Post: 07-30-2004, 01:46 PM
