Results 1 to 4 of 4
Thread: Question about best way to trim a Metra install kit
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    I know this is so simple I've been reluctant to ask, but after searching I haven't come across any direct answers. If I need to trim the opening of my Metra install kit to better accomodate an install, what is the best way to do so? With a utility knife, Dremel, lazer beam? Again, really simple, but as they say "measure twice cut once". I need to take off less than 1/4 inch, and I want to make sure it comes out clean the first time. The Metra Kit (95-3302) is just ever so slighty too small on the inside for the face of my Infill G4.
    _
    Mar 2004
    Little Elm, Texas
    depends on how much you need to trim. If it's just a bit, I'd get a file and use that.
    Not a nail file, but something like a metal or plastic file.
    Jan Bennett
    Elsewhere
    You can also use a razor knife if you heat it up with a torch or a lighter.
    VOILA!
    A hot-knife.
    How about the Wiki?
    Jun 2007
    Annapolis, MD
    ah, hadn't thought of that. Glad I asked.
  1. '06 Mazda3 + metra single DIN dash kit + AVIC-D2
    By Trevoke in forum Fabrication
    Last Post: 06-29-2006, 10:05 AM
  2. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  3. Newbie question. What software to install?
    By Bergetun in forum Newbie
    Last Post: 03-16-2004, 08:10 PM
  4. Lilliput install question
    By Audamn in forum LCD/Display
    Last Post: 12-13-2003, 07:29 PM
  5. Opus Install Question
    By IIJasonII in forum Power Supplies
    Last Post: 12-09-2003, 01:58 AM
