Results 1 to 10 of 18
Thread: Transmission intergration
    Jul 2007
    Im about to start desigining my car pc and 1 feature we are trying to look into more is intergrating the car pc to control the changing of gears in the Auto Transmission.
    What are your thoughts
    Feb 2006
    Vancouver, BC
    you can get electronic transmissions for hot rods. lets you select gears at a push of a button. I don't think I would have the computer control this feature nor try to develop it on my own. I'd go with a proven product which has the necessary redundancies and safety settings.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    And, can you imagine what would happen if the computer hung at 80 mph on the freeway, and it threw the tranny into park. OUCH.
    Not nexessarily a good idea. Interesting, but not really a good idea.
    Having said that, integrating such a thing could be as easy as some relays, and a relay controller (search the forum) depending on the transmission type, and how you plan to use it.
    Michael
    Elsewhere
    Even moreso, I could see a drag racer (as an example) using inputs fromt eh engine (RPM, primarily) and shifting at a certain RPM, all PC controlled.
    There's a substantial amount of risk by having a PC handle that chore, to be certain. But it's an interesting idea.
    I think you're going to get more mileage from using the PC with tuning software & a modern motor/trans where you can tweak shift points and the like.
    How about the Wiki?
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Think you'd want a more dedicated solution, like an embedded processor or at least something running a real time OS and just use a PC to view status,etc.
    Unless you really know your stuff, I'd probably pass.
    Jul 2007
    Im not after the Carpc to change the actual gears and shift changes, although that would be awesome and help with times on the track. Im more thinking about just changing from park to reverse, Neutral to Drive.
    There would need to be dedicated safety settings built into the system.
    I discussed this with my electrical engineer and the safety precaustions we can built in seem prety easy.
    A Trigger can be made to only allow changes to be made when the motors RPM are under a certain level along with only working when the driver has hsi foot on the handbrake
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by XCESIV View Post
    MOST tranmission require the movement of the lever. You will need strong servos/motors/pneumatics to move them. It won't be easy, and there is no real reason to do it, well except because it is cool.
    With all your safeties, what will control them, the computer. If not, then why even use the computer to change gears. Might as well use whatever will control/be the safeties to change the gears.
    Michael
    Jul 2007
    Quote Originally Posted by Wiredwrx View Post
    ............It won't be easy, and there is no real reason to do it, well except because it is cool..........
    Thats exactly it. Its cool. There is no need to do any mods to the car, but we all do it.
    ..........With all your safeties, what will control them, the computer. If not, then why even use the computer to change gears. Might as well use whatever will control/be the safeties to change the gears......
    The safeties will be triggered by relays im guessing. These will be triggered by either pressure on the brake pedal or a electronic signal from the cars computer saying the rpm are under a certain limit.
    I am removing as many buttons, etc from the dash as possible. Simplifying the car as much as possible.
    The leaver we see in the cabin in the car is alot more complicated than the actual leaver that changes the gears in the transmission. The leaver in the cabin is normally gated to reduce the chance of wrong gear changes. This normally requiring a button to be pushed or handle lifted.
    The actual transmission has nothing like this (Well not on the transmission im using) Its basically a leaver than moves to certain points for each gear.
    I have been put under the impression that merc or bmw have a carpc now that does this.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    I am aware how transmissions work.
    How will relays keep the thing from shifting. How will you get over the hurdle of shifting from drive to 3-2-1 if you have to push the brake, or be under a certain rpm. What is the computer won't boot, then what. No drive, or do you then use the lever which you have removed, or are you planning on leaving the lever there anyway. If so, how does that simplify anything. And, before you can pull out of yourdriveway, you have to wait for the computer to boot. That can take like 30 seconds.
    But again, like I have said, you can get a relay controller, or do a servo/linear actuator to move the lever and have them controlled by the computer.
    A better choice is using a basic stamp or a PIC. They don't crash, and "boot" in less than a second.
    Michael
    Michael
    Apr 2005
    Boston, MA
    Michael
    I vote PIC (or AVR etc), I don't think a stamp would give you enough control. Do stamps let you hook into the watchdog timer? I don't recall.
  1. Looking for a New Transmission for 91 Celica
    By McRob in forum Off Topic
    Last Post: 12-07-2006, 09:13 PM
  2. Transmission Temp
    By pshadwick in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 10:13 AM
  3. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  4. OBD-II software that reads automatic transmission temperature
    By 97q45t in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-01-2005, 04:19 AM
  5. Data transmission over short distance using light???
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 04-22-2002, 03:32 PM
