Results 1 to 5 of 5
Thread: Monsoon Audio System
    Jul 2007
    Hi,
    I'm not sure if this is the correct place to post this but I'll give it a shot. I recently purchased a 2003 VW Jetta GLS that has the Monsoon Audio system installed. I purchased this car from a non-VW dealership and they couldn't answer these questions. Any help would be much appreciated.
    1.) Does the unit play .mp3's?
    2.) Is it a single CD player?
    3.) Does it come with a separate amp?
    Thanks,
    -Don..
    Elsewhere
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
    Jul 2007
    hope this helps
    Not sure if the newer models play mp3s I have an 01 and it does not but try playing a mp3 formated cd and find out: )
    If it is a single cd the cd insert will be in the head unit if it is a multi disc there should be a cd changer in the trunk mounted on the left side of the compartment behind a hidden door.
    All monsoon systems come with an amp mine was mounted in the trunk on the right hand side under the rear dash.
    good luck
    Jan 2006
    Lexington, KY
    It does not play mp3.
    For CD changer and an amp check your trunk.
    May 2006
    Quote Originally Posted by dallen View Post
    Hi,
    Thanks,
    -Don..
    1) Nope
    2) Yep
    3) Yep, if you have Monsoon it's in the rear left corner of your trunk, there's a flip down lid.
  1. Replies: 5
    Last Post: 07-15-2007, 08:11 AM
  2. Ground audio system to battery??
    By eddie in forum Car Audio
    Last Post: 05-30-2006, 03:34 PM
  3. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-31-2001, 12:30 AM
